hi
I build the pcb eduardo1979 put in page 17 (S.M.W.555.zip)
but when i turn S.M.W i have just noise in speaker and volumes not working
the amplitude is just working and when i turning it; the noise is going to down
i use BD140 in replace of bd135 (the back of BD140 is Side to 479U and Forward of it is side to 7809 regulator)
can anybody help me please...
Serbian "Most Wanted"
Those are for soft limiting (Q
and bias. The oscillator provides triangular wave, so the comparator ON periods are affected with signal voltage, as dictated by bias and threshold controls.
Hi everyone,
I noticed, that in the latest versions (ver. 2.0 and 3.0) of the scheme are added some components, missing in the initial versions:
Q8, R42, R43, R44, C25
What is the purpose of these elements - to maintain the threshold to be calm or...?
Since do not have the opportunity at the moment to experiment this circuit topology of this type of schemes but I am curious about this and I'd like to comment on it... What are your opinions?
thanks Daver
i'll work on it to find problems by myself
Im going to build a DD coil and test it and put results here
I didn't say there are any mistakes. The design is refined to the desired specifications of the author(s) and there is nothing wrong with it. It is entirely my problem that I want it to do somehow different, and there is no guarantee you'd like my mods. For example, I'd want it to have a much slower motion response, yet it takes quite long till it stabilises (if ever) and most people would not like it at all.
thanks Daver for help
can you tell us about this changes? (is ver3.1 have mistake?)
if you can tell us about all mistake, please show us on schematic
thanks again for your helps.
No. I was considering making it with some changes, but the number of changes happen to be too many and I decided to develop a completely new thing.
Anyway, I like this project. It has the best front end of all the VLF detectors around.
Supplying a detector from 16V adapter is a bad idea. You should try batteries instead. Anything connected to mains is a great source of noise.
thanks Daver
i use 16v adapter for test but i have only noise on the speaker and q10 going hot
can you help me for this problem?
are you make this ver (smw3.1) ?
Yes, busy digesting
MPSA13 and 14 are basically the same thing for your purpose.
L7810cv is not a low dropout voltage regulator (LDO) and you should have at least 3V on top of the regulated voltage, in your case 13V or more. If it is not a problem - go for it.
hi
i build smw3.1 and i have no sound (just noise)
help me please
i use MPSA14 instead of MPSA13 and L7810cv instead of LM2937
please tell me what is those pins:
M
0V
AGND
and put a Front and back picture from your smw3.1
Yes. You might experience instability at the end of battery life. LDOs are much more expensive, yet they give you more comfort in use.
can i use ka7809 Instead ic7: lm2937et-10 ?
i can't find uA7810 in our City!!!
yes, that is about the same as uA7810, but you will have to keep batt voltage above 12V
this would be good if you can get it http://www.ti.com/product/tl750m10
