Hi
Any pnp transistor can operate. Search on Google.
3906 is not in the final scheme and it is not resistance but transistor. I think before making such an arrangement should at least know a little components.
Serbian "Most Wanted"
i dont have BC327 and 2N3906 PNP transistor. which type of resistor can i replace it?
best reguard.
MNW.
Hi bravodenisu
nice project,coil,,, its PI,NOT VLF?
Whats name?
best time
j.
I think it's pretty cool and stable.
http://www.youtube.com/watch?v=0Yne4nox9AQ
My coil works better without foil. When I put tinfoil lose one two inches.
Jap thank you
I will compare my implementation, that of # 105 and # 107 and the sheme make the best until the Lmeter
If you don't leave a gap in the foil, then it looks like a shorted turn. This will completely ruin your detector's sensitivity.Originally posted by TheBreMar View PostI have one question, why there must be a gap about one cm in length when we put aluminum foil on coils???
Hi TheBreMarOriginally posted by TheBreMar View PostI decided, I'll make my own coil by some of yours recipes. All I have to do now is to steal some copper
Unfortunatly this coil I have is not mine so I can not use it to put new coils. I have one question, why there must be a gap about one cm in length when we put aluminum foil on coils??? Give me a link, I'll read it with joy!
the data about coil make "TGSL 101" (parts 1&2).
link may help http://www.geotech1.com/forums/showt...mplete-Details
best time
j.
Hi Freddy67
not worry,,, OK,,, you do SMW V2,, reply#105 PCB, is corrected schematic in reply #107,,
---SMW V2 PCB,schematic are ok,(follow).
-about handmade coil ,original coil read reply#108
best time
j.
Hi JapOriginally posted by jap View PostHi Freddy67
-No errors
the first values follow ver1,the second values follow ver2,He modified for the better.the good values the second values ver2.
best time
j.
I took the implementation of post 105 and the scheme post 107 (last known) and it is just between the two there are differences. I do not know if this is the scheme or implementation that are good.
Hi Freddy67
-No errors
best time
j.
Hi TheBreMar
-What you got from the results is not like Standard coil is 0.9mH;2,1ohms/ 14,72mH;30,6ohms.
This does not comply with this project . best time
j.
I have made some measurements, my Tx coil have 1,52 mH and 1,6 ohms, and Rx coil have 2,4 mH and 2,03 ohms. Coils are tester on 1 KHz. Coil is DD type, 16 inch by 14 inch.
Hello to all
I found some errors
R 2 is 27 k on the circuit and 2.7 k on the scheme
R 20 is 1.8 k on the circuit and 3.9 k on the scheme
R 28 is 4,7 k on the circuit and 1 k on the scheme
What are good values
Just for info: the BD 140 cooler is supply side negative (outward pcb)
With thanks and greetings
