Serbian "Most Wanted"
  • emoxristov
    Here's my card. Which potentiometers to put on the front panel.
  • kkyawhtet2010
    Yes....Thanks a lot.........Freddy
    and I want part list of this pcb
    http://www.geotech1.com/forums/attac...5&d=1352457719
    ......... please ......
  • eduardo1979
    A friend made the SMW with the original SEF 12x10 coil for Teknetics T2. There is not extra wire for coil shield. I think that at prototype (T2) the shielding is connected at the half tap of the Tx coil. But here at this project we can't ground the half tap of Tx coil. So how we can connect the coil shield???
    Also with this coil he can't take signal from oscillator more than 15V p-p.
    The shielding of the coil is connected directly to the RX coil inside the plate.
  • Geo
    Originally posted by eduardo1979 View Post
    I have not done the coil SMW. I've used an original Teknetics T2 coil. SEF 12X10.
  • eduardo1979
    Originally posted by salih View Post
    Can you tell us what the results with ( Teknetics T2 coil )
    € 1 coin more than 47 cm in air.
  • salih
  • eduardo1979
    Hi.
    Who wire did you use for coil shielding???
  • Geo
    There is no difference. The PCB can be powered both with 2x9V 18V or 12V with 8 AA batteries of 1.5 V. The coil is, I repeat to Teknetics T2, SEF Butterfly 12x10.No there's more.
    Hi.
  • salih
    hello 2 all
    is the Detector can detect gold nuggets
    I want reagent experience but do not have Tr:MPS13 and LF347 I hope you help me. what I do
  • Freddy67
    Errata and question
Name:	pcb cesar.JPG
  • Freddy67
    Hi kkyawhtet
    The right diagram is # 107 page 5. The detector is also called Cesar Caezar ... I attach the pcb Jpeg.
  • kkyawhtet2010
    Originally posted by Freddy67 View Post
    Hi kkyawhtet See # 438. It is in any case advisable to read the full article Best time
    Yeah! thanks U.. Freddy ..but I do not understand this article......... I wanna http://www.geotech1.com/forums/attac...1&d=1236545978 ( This photo of component side ) Plz........
  • Freddy67
    Hi kkyawhtet
    Best time
  • kkyawhtet2010
    plz...... I want component side of this pcb.........give me........plz.......
  • Davor
    Actually not. The best cheap choice for T1 and T3 is BC327 because of very low Rbb at about 30ohm. Fun part is that the so called "low noise" BJTs tend to have much larger Rbb and will not perform well here.
    With BC327 you may expect noise down to 1nV/sqrt(Hz), which is not bad at all. It is the key feature of this rig, so cherish it
