Serbian "Most Wanted"
  • Yes I will buy too. I have used demo version to print for etching, but I would rather professionally made boards (from ALLPCB) at AU$4-6 each, who require Gerber files, so Gerber to Sprint and Sprint to Gerber will fulfill all my needs. In the past Sven and others have converted Sprint to Gerber for me, but I don't like to impose. I am hoping I don't have to download Gerber as well to do this. I have Eagle, but have been unable to decipher its use. Also PCB Express which I have mastered, and is similar to Sprint.
    • Originally posted by walkman View Post
      Hi friends,
      I did draw SMW3 but not test it. So I do not want to add
      if you want to test if you can add.
      For all who want to test the board.
      This is the Walkman board. The parts are not displayed, but you have a picture of the board and you can follow it.
      • SMW_BOB__N_HAZIRLAMA_A__AMALARI.zip - 7.9 MBa
        • Originally posted by Tim View Post
          SMW gut onli Serbia, Balkan. Austrelia land best ML RH relik hovk. Super 3x diskrim.
          super prise pcb pcb 0.5 evro.
          [email protected]
          Izradjujem stampane plocice foto postupkom na jednostranom vitroplastu(1.55mm,35um). Izradjujem i dvostrane plocice od dvostranog vitroplasta debljine 1.55mm 35/35um.
          Minimalna narudzbina je 300 RSD.
          Obavzeno: Prilikom slanja porudzbine na E-mail potrebno je uz prilozenu dokumentaciju napisati sta je potrebno uraditi jos osim izrade jednostrane ili dvostrane plocice kako bih ste dobili cenu odmah. Primer: "Jednostrana, solder mask, busenje i stampa rasporeda,5 komada. "I dobijate ponudu za tu kombinaciju i kolicinu.
          Cenovnik upit na email, ponuda:
          • Originally posted by Toros View Post
            Thank you Toros. Much appreciated.
            • vola smw 3.0
              • Originally posted by pustareka View Post
                vola smw 3.0
                I think you mean voilà, this is a french word for "here it is"
                But where is your promised sprint layout file?
                • French, no. Latin for sure.
                  nec vola nec vestigium exstat.
                  There is nothing left (not a hollow, not a trace).
                  • Originally posted by blobber View Post
                    1. ITALY WORD.
                    Luigi Datome vola negli Stati Uniti per giocarsi la carta NBA con i Detroit Pistons.
                    Luigi Datome flies to the United States to play the NBA card with Detroit Pistons.
                    A fine luglio vola a l'Avana, a Cuba, per partecipare al Festival della Gioventù Comunista.
                    At the end of July he flew to Havana, Cuba, to attend the Communist Youth Festival.
                    English words for vola include fly, soar, fly by, fall off and pass quickly. Find more Italian words at wordhippo.com!
                    2. no promise
                    MD KROT GUT OR NO ?
                    • At least we know your nationality now.
                      Krot2XM is a good detector.
                      • thank you.
                        • hi to all
                          I make smw on start detect 1 eur on 15cm I turn off and now when I turn on nothing happend
                          I check all connections and all is good but when I blow a cold air on the pcb, he starts playing wtf?!?!
                          • Comment
                            • dodgy ic socket makes when blowing on it remove ic and check socket spread legs slightly and put back or change socket for better.
                              • yeah when I blow on ne555 going crazy I resolder all contact but nothing
