TGSL , is unstable ! so heavily for operate .
Serbian "Most Wanted"
Hi
Hi Ivconic,
According to you-which shematic work better and more stable in air/soil :caezar or TGSL.You have built both.
Ites mine error, 11.788mH. is properly value but number of turns is correct .
Best regards
I think you have the inductance values swapped over. Using my coil calculator I get TX = 2.33mH and RX = 11.788mH. Ignoring the discrepancies in the actual and calculated values, it is clear that RX should be greater than TX, not the other round. Also, even without the calculator, you can see that there is a mistake. RX is the same diameter as TX, has more turns and uses thinner wire.Therefore its inductance must be higher.Originally posted by Magma View PostAuthentically shema for CEZAR :
About coil; I suggested : 70 windings, 0.45mm wire for TX (9.77mH) and 160 windings, 0.27mm wire for Rx (2.39mH). DD coil 27cm diammeter. Diameter from coil winding is 200mm (full circle).
Yes it is true. Same thing with all Cesar detectors i have been seen so far, no matter who made it or which version was made. It suffers from what you just explained.
But than again...majority of other brands and models i tested so far acting pretty simillar also.
Cezar
Hi Ivconic,
How is the diskrimination? Is it the same through the whole lenght of the active zone? If it diskriminate correctly between 15-34sm,or begin to mix fer/non-fer.? Ibuilt almost selfsame shematic like cezar,and achieve the results just like yours,but in my case,increasing the lenght by the ferrous target,the detector begin react wrong(well,not too much,but...).
RX was taken from Fisher 1236 and TX from White's Classic. This is not my own project. I just made 2 devices according to this datas.
About coil; suggested datas are 75 windings, 0.4mm wire for TX and 160-170 windings, 0.2mm wire. DD coil 28cm diammeter. 255x137mm for one "D".
But i couldn't obtain such wire. I had 0.35mm and 0.25mm. So i made 75wind. 0.35mm and 173 wind. 0.25mm. Coil is working very good. For example; 1e coin detects at 34cm in air.
Phase is easy to adjust. Easilly rejects ferrite rod. Very good stabillity on soil. Wirements in search head are different than at TGSL. Al faraday cages are wired togather, but goes separatelly through cable, and are conected to cable shield. TX and RX leads also goes separatelly. So 4 leads cable with common shield is proper for this setup.
Hi Ivconic,
Why in your sheme solution you built the Rx preamp amplifier with few transistors instead the preamp with transistor connected as a common base amplifier?What are the advantages/disadvantages? Would you explain,what is your opinion?
Best regards
I thought this project would be easy and I might try and put on Eagle lite 3X4 board.
So, I determined that Rx coil would be 2.4mH instead of 2.4uH. Pulling out a coil calculators and working backwards, it came up with about 165mm for coil diameter, estimated.
But none of this matters because according to LTspice, the TX oscillator does not want to oscillate, and I'm not going to try and force it... .
oops
I made a mistake (again?!!
I got to looking at the audio output. When I apply what would be a "target good" input from the comparators; operating the entire subsystem
instead of just looking at the oscillator output - what occurs is the not what is desired.
Two reasons.
Change two things. Reverse the diodes (also change the resistor values to obtain the same approximate frequency as before). My fault.
I did not look at the entire audio system. Duty Cycle gets inverted in the audio transistor chain. That was my bad.
But this is not my fault: I believe you should swap the connections of V- and ground between the emitter of Q8, and R47. (This assumes that
the output of U6A goes positive with a good target, right?) You won't have a smooth
transition from no audio to full audio as target signal level increases without swapping those connections.
note: Compared to my previous post, I turned the speaker resistor around, so the "I(Rspk)" display goes positive instead of negative.
That's just a little spice oddity. I hope it doesn't add any more confusion.
Maybe it's right this time.Attached Files
Thanks Porkluvr!
This is very interesting new little thing to learn! I will include it on pcb for sure.
Hello Ivconic! There is nothing wrong with what you are showing but here's a way to use less power at your speaker by adding two diodes and one resistor.
This mod allows separate control over audio frequency and Duty Cycle. The two adjustments are not completly non-interactive but pretty much. (Hmmm... changing DC affects frequency according to the formula Fo=1/(Thigh+Tlow)?) For somebody who doesn't want a square wave audio output (because of making too much noise or using too much battery power) variable DC would be desirable.
Just make sure you don't reverse the diodes by mistake or you will have something like 95% DC instead of approximately 5% as shown here. You wouldn't hear any better and your battery life would suffer.
Just like your circuit, 1/2 LM358 could be used. It should make slightly lower output frequency.
Increase the value of the DC resistor if you need more volume. Don't go too high or you defeat the purpose.Attached Files
