Serbian "Most Wanted"
  • Originally posted by Hannu View Post
    I still need to try make better hfe matching Q1,Q2 & Q3, now it's 327...331.
    I recommend using the BC327-40. With just BC327, the results were bad.
    • rx 1 mh c 470/430 n..7.50 khz..
      .....rx 15 mh ..c 22/18 ....tx milivolt 08.0milivolt 04.0...(8milivolt / 4 milivolt..) can I help friends
      about smv...thanx
      • hi
        i wana make this coil (its orginal coil)
        Coil is 28cm DD,
        TX= 65-75 windings, 0.45mm wire,
        RX= 160-175 windings, 0.22-0.27mm wire
        What TX/RX capasitor values did i need for it?
        thanks
          Yes.
          Here it is:
          hi ivconic
          i can't open SMW1.SCH file inside the SMW1.ZIP (page 21 message 520).
          how can i open it so i was try eagle v4 v5 v6 and oracle, but not open
          please help me.
          thanks.
          • Originally posted by ypartal View Post
            hi ivconic
            please help me.
            thanks.
            You need to use WinRar arhiver and Express PCB program
            • Originally posted by Toros View Post
              Verythanks Toros
              • Originally posted by smity View Post
                This module shows the VDI ...
                Smity, what circuit did you use for the VDI here?
                • Using a circuit on a chip PIC16F88.
                  • hi
                    i build this coil for s.m.w
                    TX=45 windings, wire 0.5
                    RX=175 windings wire 0.22-25
                    can any one help me to know how to work with Amplitude , sens , Geb
                    thanks
                    • All information about the sensor is on the first pages of this topic.
                        new
                        • hell mst
                          any news on this project, does the layout work for you?#can you post the missing files for making a pcb
                            hell mst
                            you my maiı sound simülasyon ltc 1044 switched-capacitor voltage converters 2n2222 ...bc547...2n2907 coin hawk trshl and voice....ok..
                            • could provide the scheme pdf
                                This is basic pcb. Tested and accurate.
                                hello can anyone tell me what is the real size of this PCB in cm or mm.
                                Thanks...
