Serbian "Most Wanted"
  • This photo has already been sent by ivconic
    Can someone explain why this capacitor is not in the lay file? ​please
    • this
      • Ivconic added this capacitor in a switch to change the pitch of the sound.
        • Thank you very much for your reply. If we don't put this capacitor, won't there be a problem?
          • It does not cause any problems in the operation of the device.
            • Think you
              • Originally posted by Emersonpaz View Post
                Hello friend Marty is a jumper the same ones used in used computer bios[ATTACH]57742[/ATTACH][ATTACH]57743[/ATTACH][ATTACH]57744[/ATTACH]
                Greetings to everyone,
                in my hand
                TX 1.537 MH 3 om
                RX 11.08MH 26.2 om
                32x27 there is a title,protected with foil.
                What should be the appropriate capacitor value for the best depth and frequency suitable for these values?
                yours truly
                Gurdal
                • Hello colleagues, I have a simple question. Where should the oscilloscope be connected to nulling the coils? Pin 8 lf347 or pin 1 & 14? Thanks!
                  • here mate
                    • As I thought. I ask because when I place the coils one next to the other and look for the minimum sine wave it gets destroyed. Thank you Iidl. I continue to search the problem
                      • I found the problem. The cable I am using is the problem, 4 core total shielded 2547.
                        • Hello everyone. Does anyone know the value of this diode?
                          tanks,
                          • Originally posted by ata View Post
                            tanks,
                            Speaker connect points
                            • Thank you very much for your reply Mr walkman,
                              I apologize
                              The picture I sent was not clear
                              I mean the diode below​
                              • And I will also be very grateful if you tell me the values ​​of these capacitors
