Whites Surf PI schematic
  • sukri01
    I need some advice on my surf XX board.. Ive made an 11" coil with approximate inductance of 500uH, it had good depth but not stable at the beach, always causes false signal. i need to swing very very slow to avoid falses.. i'm using aluminium tape for shielding. if damping resistor is the problem, can anyone give tips for tuning the damping resistor correctly. ? thanks..
  • Radvis
    The damping resistor is R6, and should be 390R.
    R6 385ohms measured by multimeter.
  • Qiaozhi
    Originally posted by Radvis View Post
    I will try replacing cable. Damping resistor is R8 in Silverdogs surf kit, am i right ? Its 1k.
  • Radvis
    That cable should be fine, but try connecting the coil directly to the board using a short length of flex to eliminate the coax cable from the equation.
    Also, what value of damping resistor are you using?
  • Qiaozhi
    I already attached my cable to coil so no metal clamp is used anymore, adjusted offset to 0 volt, but still the same result. Adjusting delay makes some difference, but nothing better. Still beeping everytime i move my coil or my cable and dont get any depth. Tried outside, where are no metal objects, wires or something like that.
    Now i am wondering if my coaxial cable can be the problem. I am using cable as in this picture. It has a layer like foil... What cables do you guys use? USB? [ATTACH=CONFIG]28525[/ATTACH]
  • Radvis
    Now i am wondering if my coaxial cable can be the problem. I am using cable as in this picture. It has a layer like foil... What cables do you guys use? USB? Click image for larger version
  • Radvis
    Originally posted by Thomas View Post
    "Maybe my soldered contacts overflowed? " the red circled areas are OK. how about the other side.
    Here you go,if they say anything
ID:	339362Click image for larger version
    Tommorow ill try adjusting trimmers without metal clamp. Thank you
  • Thomas
  • Tepco
    Metal clamp !?! You have lump of metal in the coil and expect this to work? Remove it and try again, your detector seems to work fine. You will notice different behavior of delay and threshold controls without metal clamp too.
  • Radvis
    Hello everyone,
    i have read all posts in this thread, but still can't figure out whats wrong with my surf pro. The problem is that i get like few centimeters depth on pliers and everytime when i move my coil or its cable to any direction it makes sound response. Tried going outside where no metal objects or wireless or anything like that exists.
    Surf 1.2 pi from Silverdog
    Offset set to 0 volt.
    Coil diameter 230mm
    Turns 21
    Enamel wire 0.5mm
    Wire length 1586cm
    Around 230uH inductance
    1.37ohm
    coil connected with coaxial cable
    Detector responses to all pots and trimmers.
    Maybe my soldered contacts overflowed? (see picture below, marked red where contacts ar soldered together)
    And video showing how it all looks like. (metal clamp used temporarely, because i haven't glued cable yet, no difference without them)
    I am sorry for my english and thank you for any suggestions what could be the problem.
  • bernte_one
    Originally posted by daverave View Post
    been tweaking my surf pi and modified it and now i can get 20" depth on a old english nickle half crown so very pleased with its proformance.
    video evidence
  • 6666
    Would you mind a few details please.
  • sdesic
    Hi Dave,
    nickel half crown (1947-194 is about 32 mm ?
    What is difference between surf pi and surf pi pro in depth for you ?
    Can you please explain your modifications on surf pi.
    How big is coil, how many turns and what type of wire is it ?
    I was building bigger coil for more depth for my surf pi pro... coil about 32 cm...
  • daverave
  • multieagle
    Thanks for not jumping all over me!!! It was a faulty pot. Now working great. Should have tested before jumping aboard here.
