Full m/lab SD2000 schematics
Originally posted by Anis View PostHi genius, finally I ve complete my work on this big project,
First start was with bad result (no sound), so I v started with cheking voltages +5v -5v, here I was a little bit confused with references GRND/GND(=+VB) as below pictures, so please can any one help ...[ATTACH]48596[/ATTACH][ATTACH]48597[/ATTACH]
It is Very common to have the Battery Positive to be circuit Ground in PI detectors.
"Ground" is a bad term, better if it is named "Common" or even "Zero".
Hi Waltr, thank you for your replay, if I understand,to measure the:Originally posted by waltr View PostIt is Very common to have the Battery Positive to be circuit Ground in PI detectors.
* +/- 5V with multimeter connected to common and (one time to +5V line, one time to -5V)
In this case +5V is ok for all IC, -5V is bad= 0.4V
*measure signal's with scope, same grounded to common and sensor to test points.
m I right?
Looking at the SD2000 Power supply and regulator page os schematic:
That sound like the correct way to measure the +/-5V PSs.
Are you measuring PS WITHOUT any chip that use the +/- PS installed?
Problem could be in the -5V circuit or you have a short or bad chip somewhere.
Do note that it looks like the transistor XTX688 in the -5V is shown backwards. Emiter should point to the lower Voltage.
The value isn't critical. I used 100K because I had one.What should be the variable resistor TONE ADJUST PRE-SET on the circuit under LM13600
The schematic by ZED is 100% correct.Do note that it looks like the transistor XTX688 in the -5V is shown backwards. Emiter should point to the lower Voltage.
