Superscan PI
Bom dia KT, estou procurando um arquivo que vi em algum lugar do forum, ? de goldscan e foi uma c?pia reversa feita atrav?s de fotos originais, se puder me ajudar me direcionando com informa??es aqui, desde j? agrade?o pela disponibilidade, caso contr?rio agrade?o assim mesmo, e um ano novo repleto de sa?de e boas realiza??es, obrigado.
- Likes 1
Translated:Originally posted by Voyager View PostBom dia KT, estou procurando um arquivo que vi em algum lugar do forum, ? de goldscan e foi uma c?pia reversa feita atrav?s de fotos originais, se puder me ajudar me direcionando com informa??es aqui, desde j? agrade?o pela disponibilidade, caso contr?rio agrade?o assim mesmo, e um ano novo repleto de sa?de e boas realiza??es, obrigado.
Good morning KT, I'm looking for a file I saw somewhere on the forum, ? from goldscan and it was a reverse copy made through original photos, if you can help me by directing me with information here, since now? I thank you for your availability, otherwise I thank you anyway, and a new year filled with health and good achievements, thank you.
https://www.geotech1.com/forums/show...oldscan-IVHere it is slightly wrong, the forum has the correct schematic to fix it
does someone knows the function of the diode in front of the 555 timer (Pin 7)? See red box in the schematic.
- Likes 1
Well, the schematic of the circuit did not match with the pcb that my friends placed, for example, the bases of the MOSFETs j112 and j113 were shifted, and for example, the power supply line in the vco part of the sound was wrong, and in the doubler part, the voltage +5v and -5v, unfortunately, there were mistakes, for example, instead of diode 4007 instead of 4148 It has been used and a number of others. I mean, has anyone succeeded in setting up the circuit with this schematic, and if there are any special modifications, please post them so that I can set up the circuit. My circuit is still in trouble and does not have a metal sense. please help
