I came across to this interesting idea today.
It should be pretty much "synchronized" and shouldn't involve any significant noise amount from power inverter to the rest of circuitry.
Now, the rest of GS circuitry must be adapted to this solution.
Real art would be most proper ground plane redistribution on future pcb.
Now... i am under real doubts and also very tempted to try to use "virtual ground" formed at U2-U5 stage as main pcb ground plane, instead as it was done at original GS4.
I could use others opinion on this.
This is more interesting to me than all the rests of circuitry.
[ATTACH]27374[/ATTACH]
Ivconic, I wonder if I could run this scheme with a duty cycle of 10% alrrededor, as befits the TX pulse GS4.
Jose
You did some very nice work on a power supply for Tinkerers IB P.I. Do you think you could bash up a suitable low noise power supply replacement for the GS4 ? I'm not really au fait with electronics. I try to cut and paste, and would probably end up doing something terribly silly.
Thanks greylourie.
I am using 15 pF and seems to work well instead of C24.
I think I read that Carl said it was possibly a mistake copying and pasting.
Jose
I would add: a little microprocessor could semplify all the timing generation and audio processing of this project...
Altair, I think you have a good suggestion. But first I think the most important things to do are : implement zero offset opamps, simplify/remove some switches, improve/copy/create low noise power supply.
Once those things are successfully done, then your suggestion becomes a logical and easy step.....
This thread is full of good tips on improving the GS4. See posts by Reg, Jose, Max and others.
Thanks Ivconic by the PCB. I'm surprised this work.
Experiences realized with LM337, one can see in previous post, this scheme is equal to that appeared in the equemas GS5.
I think the purpose of using the LM337 was to limit the current in some GS5 that they had a TX pulse width 200 ns, and a high frequency of 3000 Hz alrrededor in order to use different low resistance coils, without overloading the stage TX, and limit the power consumption.
Then I stop using those GS5, which had a pulse width of 100 ns, depending can remember having read in the forum Findmall.
Currently I do not use this limiter, because I am using the original frequency of 450-550 Hz and a pulse width of 120 ns.
Many problems related to noise, left when replacing the 555, by 7660.
Jose
Hello ivconic
We understand that you can not make any promises. Like Jose says, it is an arduous job.
Throughout this thread people such as Reg, Jose, Max and Geo have posted tips to simplify and improve on the original GS4. Both Max and Reg suggested newer type opamps. Reg highlighted the possibility of removing the need for many of the annoying offset trimmers. Reg also suggested the simplification of the High Low switch. Jose used a two stage preamp using NE5532. He experienced noise with the 5volt supply and replaced 555 with the 7660 like in the hammerhead. Think he also experimented with LM337. Geo highlighted the improvements of others, that can make the GS4 switchable both as Motion or Non Motion machine. Simplifying and modernising this machine could make it a very popular model.
I agree. I would also try to improve it's audio.
Power supply can be replaced with something more better and hopefully less noisy.
btw... i already "transfered" previous pcb draw into SL5, just to have better control over it and to much more easily perform some checks.
This is just first step in process of drawing new board.
Enjoy:
Hello ivconic
Porkluvr
I think it constestaron your question.
The only files that are able to open the PDF, but these can not be uploaded directly, so we went up the RAR files, such as those received.
Jose
Enjoy:
