  • Jose
    Maikl, this dual coil, works best for small items like gold earrings. The scope is larger and is more intense signal, the values ​​of the damping resistors are what worked well in my GS4, but may vary depending on the characteristics of the MD used.
    JoseClick image for larger version
Name:	Bobina Camp Dual.GIF
  • maikl
    Thanks for the answer Jose. These are good results. Tests are of course in-house, but switched off the TV and computer...
    I forgot to point out that the small "gold" earring, but you understand me.
    Best regards.
  • Jose
    Maiki, detection in air depends inter alia on the noise picked up by the coil when testing in the house or the workshop, in the countryside away from power lines may increase the distances.
    Tests in the air inside the house, "OFF" mode, coil 30 cm, maximum gain, delay set to 13 useg. Approx.
    The old coin 100 pesos, more than 35 cm.
    25 cent coin, 2.5 cm diameter, bronze or nickel alloy, 35 cm.
    10 cents coin bronze, 28 cm.
    Gold engagement ring, 34 cm.
    Small gold earring, 5 cm.
    This photo shows the slope, is best detected with smaller coils.
    Coke can of 333 cm3, 70 cm.
    JoséClick image for larger version
  • maikl
    Originally posted by Jose View Post
    I love watching my GS4, that will not stop ringing in the back of my house by the trash,
    Hi Jose.
    Tell me some information GS4 detection in air, for example coil 30cm, with maximum sensitivity:
    - can of Coca Cola 0,33 l ...?
    - 1 euro coin ...?
    - small earrings ... ?
  • Orbit
    2n4393 is tested the original GS 4 works exactly the same as j113 ,I'm that supersedes j113 ,all the best !!!!
  • 6666
    Looking at the RS website, they say that a 2N5459 should work in a 12volt circuit ok,
    be carefull of the legs.
  • ABDW9
    Originally posted by Reg View Post
    ABDW9,
    The J113 shouldn't be that hard to find. Where are you located? Do you have access to ebay because they have some for sale on ebay.
    As for a replacement, I am sure there are cross reference books that provide some cross reference number. Right now I don't have access to one.
    Now, the J113 is a N channel Jfet. So what you will need is a N jfet. Next you need to look at the specifications of this part and try to find one that has similar specs. Things like cutoff voltage and current at 0voltage on the gate are important.
    I suspect some of the jfets used on other PI's or for similar purpose of a switch like the TIS 75 or the 2n5485 would most likely work. However, I didn't check the pin configuration so make sure you do that. In other words, if the board is made to use the J113, make sure you place the gate, drain and source leads where they belong.
    To be honest, I am not one that is any where close to being a Jfet expert. So, I am hoping others more knowledgeable will jump in with other or better recommendations.
    One more note, these Jfets used are usually matched so at least use the same N jfet and not mix and match different fet numbers.
    Reg
    replica j113 also 2n4393 !
    Thank you my brother shaking
    Ask your thorough explanation
    Thank you for your interest
    I I live in Sudan and we have many sites to buy electronic parts, but unfortunately I did not find this element j113 I do not know why not be present to have, although I got on all the elements of the device
    For long positions this painted this component of many sites, but of no avail was not sure if they had Ohtamo my application or is this sites and fake sites only ... I do not know!!!
    You mentioned that Bomkanni use is similar in function to the power cuts and the current 0voltage important gateway.
    Does this will do the job in the GS4 enough that does not impede or no affect on the device?
    Like my use of similar 2N4393
    And thank you very much
    You all due respect salute you.
  • Jose
    Reg, I made some experiences with Delta Pulse, decreasing the width of the sample in the range of 25 to 50 useg. The result was that the gain decreased.
    I do not remember where I read in the forum, some fast driving small objects, such as gold, can be lost if the sample is wide, so do not rule out perform the experiments.
    I did some DD coils for DP, but did not walk in my GS4, apparently caused by noise in the PCB mass points, not enough experience.
    I think the GS4, can be used to detect gold nuggets, in places where the soil is highly mineralized and other PI would not work, with the limitations that are known,
    I live in a village in the province of Chaco, Argentina to 10 km of the river Paraguay, forest predominates here and the plain, the sea is more than 1000 km. The soil does not have many minerals, and no gold nuggets around here. however I performed detectors for hobby and my first MD, was the "sandcastle".
    There are places near where I live, where there was the triple alliance battles in the last century (Brazil, Argentina, Paraguay, and Bolivia) and many stories of buried treasure, but I do not do any research until now, is a project that is pending.
    Conducted tests in some natural spas around here, to find common use coins or other items of little value, so my experience as a hunter, is poor.
    I'm passionate about Pulse MD as TDI, but I know him only by youtuve pictures and videos.
    I love watching my GS4, that will not stop ringing in the back of my house by the trash, calms when adjusted to remove a nail.
    Cordial greetings
    Jose
  • Orbit
  • Reg
    ABDW9,
    Reg
  • Reg
    Jose,
    I made an error when I said you may not see much of a depth loss if you shorten the sample width. To be honest, I was thinking of a different design where multiple things change when the sample width is altered. As for the GS 4, I haven't done any calculating so I can't say for sure just what will happen but I suspect there will a be a depth loss. I just don't know how much.
    To be honest, I did do some experimenting with a somewhat similar design but at the time, I changed both the sample width and the frequency of samples so I really don't remember just what happens or by how much things change by only changing the sample width.
    One person who has done a lot of designing of PI's recommended a very short sample time, so part of my recommendation came from his advice.
    Sorry if I confused you.
    Changing the subject again, what do you plan on hunting for with your GS 4? I am also curious as to where you are located if you don't mind saying.
    Changing the subject again, the DD coil does a little better on really small targets but won't have the depth potential of a similar size mono coil. I haven't tried a balanced Concentric coil yet and that is on my agenda to build. Dave Emery's explanation is quite thorough for those who haven't read it. There is a copy of his explanation on how to build this type coil on the Geotech project page. Now there is a discussion about various coils on another thread on this forum. For those interested, it is in the coils forum under advanced PI coils.
    Reg
  • ABDW9
    Hello everyone
    I have a problem in the absence of the element (j113) What do I have to do
    Is there a replacement?
    Thank you
  • Jose
    Thanks Reg, for the comments and illustrations.
    I am using the current limiter based on LM337. Not sure if the R-value of 2.2 ohms, is suitable, do not increase this value, to keep low, the voltage difference between the input and the output of the regulator.
    The pulse width corresponding to the sample, in my GS4, is somewhat less than 20 useg.
    I will follow your advice and then comment on the results.
Name:	LM337 Reg. Corr..JPG
  • Reg
    For those of you who may be confused with the chart, here is what Eric posted back in 2002 when he posted the chart on how to use the chart.
    "Here are the curves I have used for many years. As Robert said, the range reaches a maximum when it is equal to the radius of the coil. Coils larger or smaller than this optimum will result in less range. To show how this works, along the bottom axis you see coil diameter, which is obviously 2 x the radius. So for an 11in coil, if we go up the vertical scale to A, we have 5.5in. Also note the diagonal line and the series of ever increasing semicircles. Everything to the left of this line shows increasing detection range up to the maximum where it intersects the line, then decreasing range to the right, where the semicircles are shown dashed.
    If a certain metal object is just detected at 5.5in with the 11in coil, then going larger in coil size will cause a reduction (going down the dashed side), and going smaller in coil size will have a similar effect. Initially, it won’t be much, i.e. going from 11in to 8in will only make 0.5in difference but below 4in diameter, the range will drop rapidly.
    Now, suppose with the 11in coil, you can detect an object at about 12.5in (B on the vertical scale. This indicates that the coil is not an optimum size for that particular object. If we carry on up the curve (direction of arrow) we can see that by using a 20in coil, we could gain another 2.5in (C). The curve peaks at 15in with a 30in coil. But the extra inch gained hardly makes such an unwieldy coil worth while.
    Other factors come into play of course. The curves assume that the number of turns and the coil current is the same in all cases; which it isn’t necessarily. For the same inductance value, a smaller coil has more turns, which counteracts to some degree the loss in range. Also a smaller coil will pick up less electromagnetic noise, earth’s field noise and ground effect, which make for a smoother threshold.
    The end result is, that with a small nugget that can be detected at between 5 and 7in with the 11in coil, so that it is on the top part of the curve, an 8in coil may well give a similar range. That is not to say that smaller coils do not have other advantages. Small coils and probes are very useful in rocky areas or searching in undergrowth. They have less drag too for water hunting, and less pickup from mineralised soil or conductive sea water plus better signal separation on close or multiple objects.
    One other point regarding PI, is that the small object sensitivity is largely determined by the sample pulse delay. If an object is so small, or thin, or made of high grade stainless steel, such that all the signal has decayed before sampling takes place, it would not matter how small a coil you made, it would never be picked up.
    Bed time problem for the depth junkies – If the Aquastar with a 10in coil can pick up a ring at 20in, what is the optimum size coil for maximum range, and what range could theoretically be achieved? That’s the depth at which a mere pulltab could trigger suicidal inclinations [IMG]file:///C:\DOCUME~1\Reg\LOCALS~1\Temp\msohtml1\01\clip_ima ge001.gif[/IMG]
    Eric. "
    Keep in mind this chart only gives an approximation and doesn't take into account noise problems or other anomalies. It does give a general idea of what one can expect if they build a larger coil and just what size might be the ideal size if you know what you are trying to find and have one of that object you can test.
    Now in the case in the explanation by Eric shows that if you can detect an object at 12 1/2" with a 11" coil, you gain about 2 1/2 inches in depth by almost doubling the coil size and less than 4" if you triple the coil size.
    So, this sort of shows there are depth gains but not as dramatic as one might think.
    Reg
  • Reg
    Jose,
    It sounds like you have a pretty good idea of how the GS 4works and what to try next. Varying the time between samples (R15) will display a few different things such as where the iron is eliminated. Advancing the time requires more iron signal for proper ground balance at the minimum delay and because of this may cause a slight increase in noise but not as bad as no GB or full GB.
    The R51 and C34 combination adds a small delay turning on and turning off the FET's that are there to eliminate the opposite half of the signal. In this case, a negative signal is normal and when the signal out of U12b goes positive, the FET's are turned on determined by the RV4 setting. If this stage is inhibited by activating the Hold switch, the audio heard would be a wee/woo if the threshold is high enough. This is the more common signal one hears on other PI's. Also, when the capacitor C29 or C28 are discharging, there is a time when no target could be heard. So, by quickly discharging the caps mentioned, the detector can quickly respond to different targets very close to each other.
    Changing R51 to a lower value reduces the several millisecond delay mentioned above but it is still there. This delay does cause problems.
    Changing the subject, maximum noise on this detector should happen at the None setting or when the GB control is at maximum. At any other setting of the GB there is a signal loss which should result in a reduced noise but also a reduced gain.
    Because this is a full sample and hold design, you might want to try shorter sample time. This might reduce the noise also. I think the sample time is set by C19 and R19 and R20, but I don't remember for sure. You should be able to go down to a very short sample time of less than 5 usec with little obvious difference except for possible noise. Be careful, the value of R 19 and R20 shouldn't be less than 5K according to the specs on the 4538's.
    How are you current limiting the transmit? That was originally tried on the GS 5 but abandoned later. Maximum depth will occur when the target is fully saturated and this happens at a larger tx current with pulse length designed for the metals you desire to find. Coin size objects do reasonably well with 100 usec but larger silver and copper objects or very large iron objects should show an improvement in depth with a longer pulse on time.
    Now, with that said, using a larger coil also increases the depth potential providing noise doesn't become a problem and the target signal on a target at depth provides a response deeper than half the diameter of the coil. This means if you can detect a target much deeper than 15 cm, then that target can be detected deeper with a larger coil. Just how much deeper can be sort of determined by using a graph made by Eric Foster many years ago. I have attached that chart.
    Reg
