  • Emersonpaz
    Originally posted by tifred View Post
    Hello Geo Max and hello everyone. Well...you were right, it didn't work. I'm going to start all over again.
    What is the assembly order for the module steps? I'll try to learn.​
    It didn't work??? No sign of life??? Do you have clear photos of the entire board???
  • nejdet
    Ok
  • Op04
    Originally posted by nejdet View Post
    I can't open the archives.
    Extract using winrar, its a zip file inside
  • nejdet
    Originally posted by Op04 View Post
    Updated but still need to check further, this is my attemp for Eduardo's GS5 Lite
  • Op04
  • David222
    Originally posted by eduardo1979 View Post
    Why don't you make the GS-5?
    In my opinion it is a better detector than the GS-4.
    In the past I made a LITE version of GS-5 and it worked very well.
    My LITE version has the identical time base as TDI SL.
    The VCO is very nice, because it has a CD4046.​
    https://youtube.com/shorts/2tXTbySBUD4
    Thank you.Do we need to enable the mirror option for Gerber output for pcb printing?I am confuced.You said you used a 33 cm coil,What was the wire number,inductance and resistance?I want to make it myself.Tanks
  • tifred
    you can see it how you post your requests...
    You haven't read the posts, apparently. Otherwise, you wouldn't be asking about the files. Everything you're looking for is there. If you had read them, you would have found it and wouldn't need to ask.
  • Op04
    Unverify, unchecked. GS5 lite with less cable.
  • tifred
    Thanks for your help.
    I’ll replace C2, C3, C5, and C10 with tantalum capacitors. Then I’ll finish building the circuit, and if everything works, I’ll try to learn how to use my oscilloscope to adjust VR1 and VR2 properly.
  • GeoMax
    Originally posted by Geotech11 View Post
    Your op-amp negative feedback copper spacing—what is it?
    If the spacing is not reasonable, parasitic capacitance can form and cause oscillation.​
    Hi Geotech11,
    what spacing do you think is reasonable to avoid parasitic capacitance? 10mil, 15mil or even more?
  • Geotech11
    Originally posted by Emersonpaz View Post
    Click image for larger version  Name:	20260308_195715.jpg Views:	11 Size:	567.4 KB ID:	445933 C2, C3, C5, and C10 are tantalum capacitors.C2, C3, C5, and C10 are tantalum capacitors.
  • Emersonpaz
  • Emersonpaz
    Hello, I finally received all my components and have reached this stage of the build. Could someone help me with the adjustments for V1 through V5? Do I need an oscilloscope to set them correctly?
    Click image for larger version  Name:	IMG_20260303_193130.jpg Views:	0 Size:	577.3 KB ID:	445924​
    Initially, you can leave the trimpots in the noon position. After operation, perform fine adjustments using an oscilloscope, setting the frequency range using VR2.VR1 is the 0V adjustment for the oscilloscope probe connected to the TP pin.
  • GeoMax
    Good luck… But I don't think it will work the way you're imagining, with people explaining how to adjust all the potentiometers. Judging by the board's appearance, it seems like you've simply populated it and are now asking how to "adjust" it. That's not the right way to do it. You have to populate and test the circuit module by module. Only proceed with the next module if it's working. An oscilloscope is absolutely essential.
  • tifred
