hanks José I almost finished the plate and with the space to adapt ne5532 and with the 7660 source I will use instead of ne5532 mcp602 feeding positive and negative with 100 oh
thank you very much jose for your clarifications .. in the case of q10 and q9 the pin D If it goes to earth? since by the mentioned thing now I think in q10 and q9 are not correct in the scheme?
Excuse me, I did not understand the question.
Terminal "D" of J113, is connected in pin: 2; 3; 5; 6 of U10, respectively.
So I have it in my GS4, which is working.
hello jose thank you very much for your answer ... I mean I understand j113 pin s is connected to pin 5 and 3 of u10 ... and grounded through c25 and c26 ..
hello ... I have doubts on how to connect j133 .. the Q8 and Q6 .. in some pcb appears pin 2 (s) from j113 to U10 PIN 5 and to 3 ... in other pcb appears differently, pin 1 (d) connected to pin 5 and 3 ... could someone help me? .. what would be the correct way to connect q6y q8 .. help please
hello I see an error in the position of j113 --- of pcb..1: D 2: S 3: G .. that is the order of the pins because pcb is placed in a way difirecte to the scheme?
Jose thanks for the Secuencia de Tiempos file.
Really useful for any builder should attempt to build it to have the correct timing diagram.
Hi Ranko
Set U12 as shown in the diagram.
In normal operation, the voltage at pin 8 of U12 must be 4.2 Volts negative.
Set to 0 volts, pin 7.
Set to a few negative millivolts on pin 10. Until you get around 4.2 Volts negative on pin 8.
The marked resistance of 220k. I use 22K.
Use BF245 A, B or C.
J113; J112.
Other JFETs may not work in this scheme.
Jose
can you write something about the dual tones? How have you done it?
