The data sheet says
"J111 / J112 / J113 / MMBFJ111 / MMBFJ112 / MMBFJ113N-Channel SwitchFeatures• This device is designed for low level analog switching, sample and hold circuits and chopper stabilized amplifiers.• Sourced from process 51• Source & Drain are interchangeable"
[QUOTE = 6666; 260390] Your attachment seems to be missing, but Source & Drain are interchangeable on J113 [/ QUOTE]
Originally posted by TufaN View Post
Greetings and regards jose.
I suspect your goldscan 4 in this photo.
between the scheme here and your goldscan pcb array j113 s different connection.
Drain pins on the diagram are connected to the integrated. but drain on the pcb is shelf. is the correct connection?
Originally posted by Jose View PostFor the case of Q9 and Q10, the "S" terminal is connected to ground or GND. The attached diagram is correct, although there could be some error.[ATTACH]44349[/ATTACH]
I think it should, measure the current consumption, which should be 200 to 250 mA.
The voltage should not be too high 15 or 16 volts, with those values and a good heat sink in the regulator, should not have problems. The scheme indicates 3.5 ohms for the coil, see the first page, scheme published by KT315 https://www.geotech1.com/forums/atta...6&d=1123969824
I think it should be because I use a very thick wire for the coil .. I get 1oh the wire is thick 18 .. what wire is the ideal? ... Thank you for any information
Hello, what would be the reason why the regulator 12 volts negative after a while burn, very hot when connecting the coil
Goldscan is very very tricky to get properly working.
I would strongly suggest looking into easier project like Minipulse and Barracuda which do have complete "final schematic"
all in one
Bonsoir Jose excuse me for my language;
i hope you send me the schematic final for this machine ,with allimentation schematic
it's my first experience , thank you
DEAR ALL MEMBERS. PLEAS SHARE Bernte SMD PCB COMPONENTS IN TOP AND BELOW SIDE AND SEARCH COIL DETAIL.
hello jose, I have a problem, I can not find ca85 .. What substitute can I use for ca85?
