  • ArchibaldSTM
    Everything opens fine for me... I don’t use the schematic file
  • eduardo1979
    It works really nice. But I'm interested in core performance.
    Do you still have that detector?
    To show how GEB works on it.
    And when you set the GEB to some "mineralization", after that you can test and record how it detects a Roman coin or a small gold coin.
    In "Off" mode (GEB off) my GS4 also has "enormous" depths in the air on all tested targets.
    If you still have that detector; I would be grateful if you could record minute two of the mentioned test.
    I no longer have this specific detector.
    I have something very similar, the only thing is that the timing of the samples is done digitally with an ESP32 processor.
    My tests in the video are done with the GEB activated and rejecting a hot rock. When activating and deactivating the GEB channel there is practically no difference in depth. The difference is minimal. In the past I built in GS-4 and I didn't like it because of the loss of depth with GEB mode activated. GS-5 with the 33cm MONO coil, in GEB mode activated and rejecting a hot rock, detected a gold wedding ring 33cm in the air.​
  • ZOUjiarui
    Originally posted by eduardo1979 View Post
    Why don't you make the GS-5?
    In my opinion it is a better detector than the GS-4.
    In the past I made a LITE version of GS-5 and it worked very well.
    My LITE version has the identical time base as TDI SL.
    The VCO is very nice, because it has a CD4046.​
    https://youtube.com/shorts/2tXTbySBUD4
    The schematic is damaged, please send it separately.
  • ivconic
  • eduardo1979
    Last thing I done (was lazy to record another video) is to make 25cm coil, 0.3mH / 0.9R.
    In All Metal mode with GEB slightly lose; it improved air "depths" to ~15cm on small Roman coin as well as on gold coin.
    Not good enough.
    Some other works in progress...
  • ivconic
    Not good enough.
  • ivconic
    Originally posted by kadir6141 View Post
    Hello, there is a black part on the gs4 commutator. Is this resistance? Can anyone with knowledge help? thanks.
    Probably a resistor.
    I assume it is R52 (22k) GND resistor.
  • kadir6141
  • YIVANKA
    Originally posted by ZOUjiarui View Post
    People always like to release pcb without inspection
    Should others deliver food to your mouth?:rotfl
  • ivconic
    Yes, made by Jose.
    Good "depths".
    I would be quite satisfied if I manage something like that.
  • GeoMax
    Here is another video about the GS4. I think the performance is quite remarkable. The video is already 10 years old.
  • ivconic
    Will Pulsar II work as well as GoldScan on highly mineralized soils?
    With larger coil, say 60cm and above, since it is deep enough; with coil at 30cm over the soil surface; will work just fine.
    It has no GEB, so it will be affected by mineralization if coil is lowered to ground.
    But then again, with large coil 30cm up from soil surface; you search for deep and large targets and not small items.
    Large targets will give noticeable continuous audio response... so no problem in most of the cases.
    Larger the coil and larger the target = you can lift coil more from soil surface.
    You gain two benefits from that; detector will ignore small iron junk in surface and mineralization will not have significant impact on detectors behavior.
  • ZOUjiarui
    You haven't read my posts carefully (if at all) from the beginning.
    That's not my goal, big coil and big depths... for that kind of thing I have Pulse Star 2.
    My goal is good sensitivity on the smallest targets and good GEB.
    Of course, the GS4 can also be set to work "slowly" and to work with a coil of 3x3 meters and larger!
    I don't care one bit.
  • Alexismex
    Hello guys from the forum,
    For those who want to incorporate a microprocessor for the timing in the GS4, it is a big mistake because digital generates a lot of noise .....a lot of noise that you have to clean later, and the detector loses sensitivity, the GS4 circuit is very nice as it says Ivconic, you have to look for refinements and change some parameters but in general it is a wonderful circuit that E.Foster did the design!
  • ivconic
    The horror!
    I hope that now you have a clearer picture of the situation on the grounds that I visit and about which I have written many times.
    To whom the video is not clear; let me clarify a bit...
    The first program on the video was my custom "deep" program at 7.6kHz.
    In that program, the gold coin is detected at a distance of 24 cm.
    But when I put a brick in front of a gold coin; the range drops to 14-15cm and PLUS Deus reports it as a bad target, very unstable and inaccurate response with many errors, very erratic behavior, etc.
    In the second part of the video, I switched to the Fast2 program, my custom program at 18kHz with silencer at 3 and recovery speed at 2.5
    The range to the gold coin dropped drastically to barely 14cm, and when I put a brick in front, it drops further to about 10cm or less. And it also reports the target as bad, as "trash"...
    So much for that.
    Deus coil is 22.5cm.
    :rotfl:rotfl:rotfl
    What I forgot to emphasize here is the following...
    In the video, Deus sees a gold coin through a brick in all possible wrong ways... but still sees that gold coin, even as it's "garbage".
    However, it is a recent gold coin, from 1751. And it's bigger.
    While in real conditions on real terrains, I mostly look for ancient Roman gold coins, which are slightly different in terms of alloy composition (better with more gold).
    Unfortunately, these days I have not been able to find one of these on loan for these tests.
    The problem on the real field is that Deus often does not see such gold coins at all, even as "garbage", it simply remains silent above such targets.
    So what can be seen in the video with Deus... can even be considered a "success" even though it is essentially a horror factual situation.
    So... so much for that. It definitely makes sense to build (or buy) some similar PI and go back to the old sites again.
