Tesoro Lobo news
  • homefire
    Ground Bal would be Most important here in NM.
    I need mine on the front panel for sure.
    Your getting it going good there.
  • maxbiri
    Very very nice!!!!!
    Good work
    In my lobo design i found lot of problems with coil, do you plan use a original coil?
    Bye Max
  • Legaucho
    Hello all
    Connections on rear plate now..
  • UFO
    Looks good man. I think you will enjoy the Lobo.
  • WM6
    Originally posted by Legaucho View Post
    Thank you maxbiri, for your clarification, must say that I am novice in pure electronics. I kept your info that I would not hesitate to apply if I meet some problems. again thank you and hope to read you.
    Nice work, Legaucho, congratulations. Hope all will be OK in final step.
  • Legaucho
  • maxbiri
    Hi Legaucho
    In original lobo photo i see precision capacitor and metal film 1% resistor.
    Look at brown capacitor and resistor around rx stage.
    Low thermal drift components, and low noise are important in rx stage and phase shift stage in other stage they aren't soo important.
    I hope you will havent problems but if you note instability or noise you can try change that components.
    Bye Maxbiri
  • Legaucho
    Hello all,
    I have put all components on it.
    All the best
  • joop
    Don't forget plastic metal alloy capacitors, they all start with MK. Especially MKM capacitors have low temperature drift allthough they are a bit expensive. I use them the the TX circuit of the TGSL.
  • Legaucho
    Thanks Maxbiri for your infos, if you look on the original Lobo PCB, the capacitors are basics.
    Just for information on the use of capacitors. This information is taken from the book "component technology" by Rene Besson. capacitor type
    Frequency ranges (min - max)
    standard tolerance
    use
    Paper
    d.c. - 1Mhz
    + / -20%
    + / -10%
    Decoupling B.F., filters, power factor
    Metallic paper
    d.c. - 100Mhz
    + / -20%
    Decoupling miniature connection BF, anti-parasite
    Plastic
    d.c. - 000Mhz 10
    + / -5%
    + / -1%
    All uses, agreement circuits
    Mica
    1kHz - 10 000Mhz
    + / -1%
    Agreement H.F. circuits, delay lines
    Glass
    1kHz - 10 000Mhz
    + / -1%
    Mica replaces in all applications H.F.
    Ceramic Group I
    100Hz - 10 000MHz
    + / -5%
    + / -1%
    HF power circuit, drift and HF agreement
    Ceramic group II
    1kHz - 200MHz
    + / -20%
    Decoupling H.F.
    Aluminium electrolytic
    d.c. - 1kHz
    -10% / +50%
    Decoupling, filtering, linking transistors
    Electrolytic Tantalum
    d.c. - 10kHz
    + / -20%
    All the best
  • maxbiri
    Hi Legaucho
    The pcb look very nice but i must advise you to change ceramic condensator, all condesators below 1000 pf must be poliester - polipropilene type with low temperatur drift.
    If you want use ceramic type you need NP0 type.
    bye Max
  • amtech2005
    update:
    I have started mine as a single sided circuit board . I am trying to keep mine just like the original .
    Still have a ways to go but making "slow" forward progress !!
    HH..............Eugene
  • homefire
    That's cool.
    It looks like the solder wicked up the others to the top pad.
    Seen none on that one.
    Your Da Man.
  • Legaucho
    Thanks "homefire", I don't miss this one, the copper path for this diode is below and the weld is well made, thanks again
  • homefire
    Looking good there!
