Surf PI Pro
  • porkluvr
    Make sure the LM358 is not installed backwards.
    edit: Never mind the 358 orientation, but look at this:
    If you have +5V at NE5534 pin-7, you should also see +5V at LM358 pin-8. They're supposed to be connected.
    You must be able to measure very low resistance between those two pins, if not then you may have an open trace or bad solder.
    Oh, yes I rounded 4.97 up to a 5 (I like things simple).
  • sdesic
    look for GND connection that you mentioned before
    try to power up and measure voltages on IC sockets -5V and +12V
  • Mohamed Ghitas
    i removed all ics except 7660 and nothing happens shall i measure the pins now ??
    if yes which pin shall i measure ??
  • Mohamed Ghitas
    my Readings without coil
    7660
    pin 1 :1.75 v
    pin 2: 2.43
    pin 3:0
    pin 4:-2.29
    pin 5 :-4.59
    pin 6 :0.75
    pin 7:5.02
    pin8 : 4.97
    4093
    pins 11,3,4 all -4,37V
    pin 10 :4.67
    4066 has 5V on pin 14
    4066 has -4,59V on pin 6, 8, 9 unused part
    4066 has -4,59V on pin 7
    and when i measure pin 11it gives beeb
    358 has -3.92V on pin 8
    358 has -4.95V on pin 4
    NE5534
    pin 1 :3 v
    pin 2: 0
    pin 3:0.01
    pin 4:-4.62
    pin 5 :-0.51
    pin 6 :0.06 "can control by offset"
    pin 7:4.97
    pin8 : 2.91
    NE555
    pin 1 :0 v
    pin 2: 6.35
    pin 3:10.69
    pin 4:12.34
    pin 5 :8.23
    pin 6 :6.35
    pin 7:6.35
    pin8 : 12.32
    Last edited by Mohamed Ghitas; 09-17-2013, 04:13 PM. Reason: the multimeter correction
  • Mohamed Ghitas
    okay i removed the coil and measuring the ics now
  • sdesic
    did you check orientation of your NE555 ?
    you need to pop out all ICs except 7660 and try voltages and then with NE555 same thing
    can you try measuring without coil also and before you pop them out (ICs)
  • Mohamed Ghitas
    i don't have any sound until i touch the mpsa13 base with the multimeter and the sound increase when i touch the mosfet in same time with my hand
    but there is something strange happens now i unplugged the power and trying to measure the points i found that the GND and +5, +12 all are short circutied with GND
    555 all pins are connected to the GND except pin 2,6,7
    76605 pins 3,5,7,8 also connected to GND
    is this is normal ??
    the pots gives no response only the volume and offset they made some changes in sound and in pin 6 of NE5534
  • Mohamed Ghitas
    not working
    my Readings is
    7660
    pin 1 :1.75 v
    pin 2: 2.43
    pin 3:0
    pin 4:-2.29
    pin 5 :-4.59
    pin 6 :0.75
    pin 7:5.02
    pin8 : 4.97
    4093
    pin 10 :4.67
    and when i measure pin 11it gives small beeb
    NE5534
    pin 1 :3 v
    pin 2: 0
    pin 3:0.01
    pin 4:-4.59
    pin 5 :-0.43
    pin 6 :0.14 "can control by offset"
    pin 7:4.97
    pin8 : 2.91
    NE555
    pin 1 :0 v
    pin 2: 6.25
    pin 3:10.49
    pin 4:12.12
    pin 5 :8.09
    pin 6 :6.24
    pin 7:6.23
    pin8 : 12.07
    i replaced delay 10k pot with 50k pot
    and placed 200 Ohm on the 3906 emitter
    iam using coil with diameter 125mm ,0.4 ,19 turn
    here is my circuit
    thanks in advance
  • Mohamed Ghitas
    thank you very much Carl-NC its very nice to reply me ^_^
    i have made the circuit but it didn't work :\
    so could you please tell me where the points to check with multimeter to know if the circuit is working or not ??
    thanks in advance
  • Carl-NC
    1. Yes, that's fine.
    2. Electrolyte will probably work OK. 250v ceramic will also work.
    3. 1/8W is fine. I would put the 22k in R20, probably will make the threshold a little sensitive but should work.
    4. Caps should be fine.
  • Mohamed Ghitas
    iam having some problems if any one could help me please
    1- R36 is "12 Ohm" can i replace it with 10 Ohm 1W resistor
    2- C7 which is 1uf can i replace it with electrolyte one it has + and - , if no i have another one 1uf ceramics but 250v large size is it ok ?
    3- for R20 & R18 which are 47K can i replace one of them with 22K and the other is 47k but 1/8 W is it ok ??
    4- the capacitor i used is small as shown in fig so i think its low power is it ok or shall i change them ??
    please i need fast answers i must finish this detector as soon as possible
    thanks in advance
    Mohamed Ghitas
  • sdesic
    you need to be in 250-350uF range so you need more turns
    18-21 turns...
    it is best to try with 21 and than measure depth you get with that coil and remove turn or two and measure again
  • Mohamed Ghitas
    seems that iam going to use coil wit diameter 250mm, 0.4 thickness, 13 turns
    my question is how to know the required or best uH needed ??
  • Qiaozhi
    Originally posted by sdesic View Post
    My fault
    did not read ... I assumed it was diameter
    417uH is still a bit more than required....
    is it mH (miliHenry) or microH
    than we got hacked ... by Mr.501
    The result is shown in mH. Therefore 0.417mH means 417uH.
    If your trying to get to 300uH, then try either 20 or 21 turns.
    The hacker first gained access on September 11th (911) and launched the attack on the 12th. Today is Friday the 13th.
  • sdesic
    My fault
