Pinpointer - Minimax-PP II
  • anz29
    Hi to all!!
    I have almost completed minimaxx smd, but I need mmbt4403 and 4401.
    I am currently working on zombi version through hole.
    I'll keep you informed
  • johnandles
    I recently built the picodetector,programmed the pic 12f683 from the site.www.micro-examples.com
    But dissapointed with result.
    It does detect metal,but my project has poor range.
    Tried various windings and inductances but only could locate large objects 20mm distance.(pliers etc).
    Small coins almost touching the inductor...gold ring ..forget it.
    Hope someone had better luck.
    I think I build as above pp
    John
  • johnandles
    I have just ordered the thru hole equivalent components for this PP.
    I will post results soon.
    Hopefully I will not need a sack truck to operate!
    Cheers
    john
  • zomby
    Originally posted by GSL View Post
    If you are using a 9V battery, there is no need to put the stabilizer on 3.3V. Place the stabilizer on the 5V and will be more sensitive.
    The author used the scheme Petruchio Agricultural Labourers 3V and specifically made ​​to the scheme could work with two batteries of 1.5V.
    At 5V scheme works better. In this case, you can use IC LM062.
    When you use a 5 volt stabilizer consumption rises tok.3 volts in less consumption and longer battery life
  • GSL
    Wire wound on a ferrite length of 10cm. The length of the winding 3-3.5cm
    400W , Wire 0.16-0.24.
    p.s. The Author recommended the use of circuit wire 0.3mm for better quality factor
  • johnandles
    Translation pls
    Can someone translate the coil details,for some reason I cannot cut and paste it for
    babble fish.
    Thankyou
    John
  • GSL
  • zomby
    PP
  • zomby
    works very well with some adjustments - coin 18 mm in January to detect 6 cm
  • anz29
    No news??
    Anyone has tried to build?
    I have assembled few components, I have little time unfortunately
  • anz29
    Hi Anz29
    I tried to reply to you rmessage but you do not accept pm
    "anz29 has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her."
    Sorry
    Now I have corrected, you can try again to send me a private message?
  • silverdog
    Hi Anz29
  • anz29
    MPC602 have equivalent through hole??
    How can I replace operational?
    TL072? LM358? TL082?
  • satdaveuk
    Originally posted by UFO View Post
    I guess I'm supposed be impressed because you were certified as a radio technician in the 1990s?
    Since we are browbeating, I design and build my own amplifiers with technology from the 1930s.
    Hells bells. thats got to be the biggest pinpointer ive seen, does it come with sack truck
  • DavidB
    Hey UFO that's a cool tube amp, looks like a classic push pull stereo amp with 6L6's in parallel.
