In another post, someone suggested that a detector could be built by only using one channel, i.e. the DISC channel. If you try this experiment you will find that it works ok in an air test, but will react horribly to ferrite, and will be unusable in the field
I agree here.
One thing though - i thought for a uniform ground matrix and level sweep the ground signal frequeny is DC.
If it was then it would be outside of the Disc filter passband and would not pose a problem.
I guess the problem is that the ground varies a lot during a sweep and breaks through into the disc filter passband and would be a problem.
S
I agree here.
S
