Hi.
Some years ago i posted the below table.
As i see now, TDI detected one gold coin as high conductivity with delay=10 and GB between 7 and 11. But for 45 coins it reversed the conductivity!!!!!.
For delay=10 and GB= 7...9 TDI has the lower depth for gold. So I must make again the test with the 45 coins and i think that it is time to change the adjusting of the TDI and the way that i use it. Maybe it is time to keep low or high GB and the coil far from the ground ......
. TDI has problem.
. If i"ll put the GB=6 then it detects the coin at 4..5 cm only.
