Since I always had the intention to improve and mod detectors
to the hilt, especially the best and deepest ones, I'm absolutly
satisfied now with the new Makro Racer!
The only thing is that the speaker-gaps on the lower side have
to be closed from water by default because this is the region
where the detector stands on the floor while digging and
if there is wet grass etc. the moisture can easily penetrate the housing.
See the pix below - the solution is very simple, even some stripes of
tape are enough but of course I made it as perfect as possible.
The Pro-Package comes with a special cover for that housing
but neverthless any Racer should be directly secured from water!
You even can see the paper of the loudspeaker behind the gaps.
For everything else I can assure you top features and quality!
The unbelievable thing:
The Racer even detects meteorites or special mineralized stones!
Found it out by myself, this is not described in the manual.
The Racer also displays depth and metal-value on its screen,
has manual ground balance, different sound for different metals,
ready to go even for beginners, easy to use pinpoint trigger switch
and LED-lamp plus backlighted display for perfect cave or night-search.
Depth is the same good as with the DeepHunter's motion circuit,
its super lightweight, also the additional 40cm coil is ultra light
and its very easy to adjust with the up-down / left-right menu buttons.
The name Racer stands for highest efficiency because its very lightweight
and ultra deep so its perfect for very fast going or during treasure-hunts,
especially while using the 40cm coil for huge areas.
The recovery speed (signal processing) also is very fast.
In the next time I will test how good is the electro-smog immunity,
how deep it really is and how good it compares with other MDs but
after some simple tests I'm already pretty shure it will do a great job.
Personally for me it's already a big victory because now after many years
of engagement everyone can buy a super valuable detector from Makro
for just ca. 600 Euros or Dollars and will absolutly benefit from all the
developments, knowhow and improvements we wanted to have since
the last 5 years. The Racer represents not just my and others important
improvement suggests (experiences from the active treasure-hunters)
but also the spirit of turkish engineering perfection and innovative ideas.
Just close the speaker-hole with some tape or glue some plastic-sheet
over it and everything is fine. This is important technical info because
otherwise the detector may get serious problems if the grass is wet etc.
Save is save, no matter with or without additional protection-cover.
If someone is unlucky even some thin branch etc. could stick into the
speaker hole from below and destroys its membrane or even water could
run into it. So its important to prevent all such dangers in the first place.
btw. the 6,3mm headphone jack has its own waterproof rubber-gum-cap!
Of course the speaker still is loud enough if you make it water-protected.
If you have technical questions etc. you can ask me and I also may
show you the results of my performance- and compare tests -
with the standard and the 40cm coil.
By the way: I could already detect a cannonball in the living-room with it
- at almost 80cm with high electro-smog and just 65% sensitivity!
So I'm really curious how it performs with natural conditions!
but of course I still went on for another 3 hours with usual hunting!
they can try to beat the Racer.
