moisture volume failure repair solution (solved)
Thx for your help, Skippy. This was real tricky, because sometimes the volume started to get
loud again out of nowhere and then it went back to quiet again.
Some sort of electronic-lose-contact, but not by cable or oxidated contacts! Crazy stuff.
After some tests with the potentiometer I found out by chance that the volume gets back
to normal - all the time! - after some 1-5k resistor was added! 2,2k Ohm was the optimal value.
In the beginning I thought that water created some rusty contact inside of the poti,
but this wasn't the case. The poti acts now with the 2,2k resistor complete normal -
from quiet volume to pretty loud and both channels - speaker and headphone.
But the speaker will get real quiet if some thicker plastic-sheet was glued over it.
So some air-holes are a must and are also better to save battery-power,
cause that way the volume just has to be turned up a little bit.
2-3 stripes of duct-tape over it and it should be water-proofed enough.
And I found another 2 holes where water could come in (see pix below).
This is where the pole gets attached to the plastic.
Water-resistant but not too strong glue is the solution!
Not too strong so everything is still openable if it should be needed.
So don't use super-glue to make this housing water-proofed.
btw. I have covered now the complete PCB with black color-spray - both sides!
Creates no electrionical-problems but helps to keep the moisture away!
Anyway, we are on the way to perfection with the Racer and perfection is great and important!
Meanwhile we can detect stuff double that deep as 25 years ago and
we can watch movies and we have video-games in full-HD!
Mobile video-chat via smart-phone also was nothing than science-fiction before, now we have it!
Modern kids have no idea how this was 20 years ago or how it would be today
without improvements and perfectionating stuff.
So its worth the fight, even if many just wanna enjoy all the improvements and
think they just have to spent some money to get it.
btw. perfection is just another word for well made or improved creativity
which is a motivation for many people anyway.
What's now is still missing is a 66cm (2ft) coil, ultra-light-weight!
Because those real deep 1m coils are not that easy to handle
and for most treasure-hunters too expensive.
Some 55-60cm coil also would be already a very good step forward.
Per instance 2 days ago I found a 1 pound cannon-ball 300 meters
further away of an already very far away know find-region!
Without a real large coil someone simply can't handle such huge distances and areas!
Especially those far too many and stressing sweepings with small coils (25-30cm)
can became very annoying after a short time - much more than the coils weight.
But for the moment I'm really happy with the Makro Racer and that there is
a 40cm coil available! Compared to the also very deep CoinFinder CF77 it's now
much easier and better adjustable with its LCD-screen and all the additional features.
