WATERPROOF POTENTIOMETER QUESTION
  • #91
    my machine goes under water salt once a week standard pots no probs about 7 months now listen to me i dont understand you guys are ****ed im pulling 70 year old pennies out the ocean
    • #92
      Hi Digit,
      Had fun building the whole thing. It's nice you have much space in your enclosure ... envy.
      Polymer
      Hi junkhunter,
      Sheesh, your detector knobs sure look the same. Must be some outfit in China making boatloads of those things ...
      Your solution is nice and simple, I like that. The thought of greasing up the shaft pots did cross my mind, but I didn't
      have any idea of how well it would keep water out in surf or depth. So I decided not to do that.
      How deep you dive with your detector?
      Polymer
      • #93
        Originally posted by SVEN1 View Post
        I picked up a really nice basic Ikelite cube. Small, 1/4" thick with no lens ports to cover. A bit heavy but rated to 200' under water depth.
        bought Ikelite vintage one from US seller at ebay. thank you lots for the suggection.
        • #94
          Ikelite case arrived.
          • #95
            • #96
              • #97
                I got some test on ordinary external pot and found that it survive my water pressure test..
                • #98
                  ok. he answered where to buy the housing of whites while his housing is ikelite.
                  i wrote to whites...
                  • #99
                    this is the proud in his conceit refused to answer me on a simple request. do not say me that whites is friendly.
                    Sorry we do not ship out of the country.
                    Mary Hudson
                    Whites Electronics
                    Customer Service
                    (541) 367-6121 x 154
                    [email protected]
                    Sent: Tuesday, November 15, 2016 9:30 AM
                    To: Mary Hudson <[email protected]>
                    Subject: Re: Customer Service request from whiteselectronics.com
                    hello Mary,
                    i am located in EU, but i always find people in US.
                    Lietuva is something unknown terraincognito for your part of the world as a fact.
                    best wishes
                    2016-11-15 18:18 GMT+02:00 Mary Hudson <[email protected]>:
                    Where are you located?
                    Mary Hudson
                    Whites Electronics
                    Customer Service
                    [email protected]
                    Sent: Tuesday, November 15, 2016 4:47 AM
                    Subject: Customer Service request from whiteselectronics.com
                    11/15/2016
                    John
                    [email protected]
                    hello,
                    can you tell me me i can buy a surfmaster dual field field control box with side clamos, o,ring, from you? how much the cost?
                    • Vishay Sfernice - Fully Sealed Potentiometer Military and Professional Grade - 15 Euro a POP...
                      • Hello,
                        I'm collecting components to build an MPP detector.
                        I was wondering whether these Bourne 3310 IP67 pots would be suitable?
                        They are quite small and I'm not sure what power rating is required for the MPP pots.
                        Also, the MPP build instructions call for a 250K audio threshold pot. The Bourne 3310 is only available in 200K and 500K. Which one of these will work without limitation?
                        Thanks,
                        Andrew
                        • There is absolutely minimal power flowing through any of the pots, so the Bourns pots will definitely be suitable.
                          For the audio (threshold) pot I would select the 200k, although either would probably work ok.
                          • Thanks Qiaozhi. Hopefully the 1/8" plastic shafts on the 3110 pots are up to the job too..
                            • underwater from ordinary how to do
                              • Thanks kt315. I'll definitely try that. I have some APM Hexseals coming to try too. Looks easy to make most potentiometers IP67 or better.
