Test set-up
Green, your tests have been very interesting and educational. One thing that seems to have evolved from them, is a "standard target" of a 1/4x1/4 inch can side, aluminum target. Maybe we should start with that. It is a target that anyone can easily make at no cost. Actually it took me quite a few tries to get the size reasonably close, so we probably need to allow for some tolerance. Inches? Millimeters? Mabe a set of targets, let's say 5x5mm, 10x10mm, 20x20mm
30x30mm?
The swinging target pendulum:
A glass bottle seems to work OK. A longish shaft tends to wobble more. Maybe a glass bottle filled with different kinds of sand, resistive, permeable etc. might be a good idea. The target stuck on the bottom with some double sided tape. The more the weight is concentrated on the end that is closest to the coil, the more stable it is. The longer the string that suspends it, the flatter the curve, but we are limited by the height of the ceiling.
The coil, used in the test above, is induction balanced. About 700uH inductance, 24cm diameter, wound with enamelled magnet wire AWG 19 or 20. The target was 35mm above the center of the coil housing, somewhere near 40mm from the coil wires, at the closest part of the swing. The coil sits on a plastic box about 44cm above the floor. All sorts of re-bars and copper water pipes in the reinforced concrete floor. I have not measured the coil current, as the PSU and Scope are non-isolated and make a short. Will setup a measuring scheme today. Also will work on the schematic today.
KingJL seems to have made some test circuit PCB's, I have not had the time to look at them yet.
Originally posted by green
30x30mm?
