Magnum on steroids!
  • Koala
    Originally posted by vlambers View Post
    Decided to slightly reduce the size of the device, it turned out 2x frequency (the place for the capacitors on the board 18 - 8 (or what we want), the board under the gainta g1910, now on / off, tone and frequency - "buttons", the choice of frequencies is implemented via relays (like on 5 mask), the indication of operating modes is introduced, the microcircuit 4041 has been removed, capacitors have a choice of ceramics or film ...
    Wow. That's really small and neat enclosure.
    Looks really good.
    Wait to here how it preforms.
  • Toros
    Originally posted by pustareka View Post
    best BUY adg444 15v 70 om resistance work super good.
    http://pdf.datasheetcatalog.com/data...897adg441_.pdf
    If we are guided by your logic, the DG444 is an even better option because there is low on-resistance = 50 Ω
  • Gwil
    Why is the 'on' resistance of the 4053 important? There's another 100k in series with each output, which is many times larger.
    Also, I can see why a lower noise op amp would be better than an LM324 but its offset voltage doesn't seem to be very important (unless it's seriously unstable).
  • vlambers
  • pustareka
    Originally posted by Artyom View Post
    All this is your assumption ... Draw and share a scheme that will work better.
    read factory data.noassumption no fantazy no fake.factory sxeme work ok. trak signal highway. you see and mesure. no kill signal big resistance. need 15v no 5 or 3 or 1. test protobord work.
  • Artyom
    Q1 is what ?
    bad sxema ?
    paralel 2 adg444 super senzitive good signal best depth and coins cash in hand. resistance 35 om. super good work 15v.
    lm324 bad very bad ic u1c u1d dont put. need ICL7650 CHOPER IC x 2IC. Super ic work. Choper boot depth 30% garante.
    ICL7650/53 are Improved Second Sources toICL7650B/53B♦ Lower Supply Current: 2mA♦ Low Offset Voltage: 1µV♦ No Offset Voltage Trimming Needed♦ High-Gain CMRR and PSRR: 120dB min♦ Lower Offset Drift with Time and Temperature♦ Extended Common-Mode Voltage Range♦ Low DC Input Bias Current: 10pA♦ Monolithic, Low-Power CMOS Design https://datasheets.maximintegrated.c...0-ICL7650B.pdf
    magnum best work 15v power no no 5v. power 18v , stabilizer 15v. dekupled low broom. lm317.
  • pustareka
    Q1 is what ?
    bad sxema ?
  • pustareka
    sxema ok work -not work
    bad very bad 4053 bad choise IC. not good 2500 kom resistance work bad- need 175 om at 15v
  • pustareka
    I devices operate on 3 frequency: 8 (5) -12 (10) -18kGts.
    Sent pcb serbia?
    prise is 1 pcb ?
    prise is all kit componant plus pcb ?
  • pustareka
    Originally posted by MARKORAM94 View Post
    you have here corect pcb and sch my problem was fixed, my friend orbit found litle problem and fix them
    he testing them and work like golden mask
    Thanks Orbit
    Thank youMARKORAM94
  • MARKORAM94
    link ?
    schema correct, pcb correct, no smt only tmt. post all here rusian forum. thanks. lobofoma best gold seeds nugets roma sexterous. anderwater also best.
    Thanks Orbit
  • Koala
    Vlaser wrote over on MD4U.RU
    "It's time to try out the mask 4. Was pleasantly surprised when using the device began picking out a coin for a coin on the trash. The DD coil is slightly larger than the open palm
    Deus, Fisher 75 and safaris are blinded in this place. Worked black-colored as a machine gun. Very sensitive to detail, does not miss. Very satisfied with the device.
    _________________
    _________________
    Tesoro Cibola.
    TGSL.
    Tesoro lobo mod.
    Kid FM
    Verator.
    Clone AVR.
    Chance.
    Fisher 1266-х.
    Tesoro ELDORADO
    Terminator 3.
    Minelab Musketer.
    White's IDX PRO
    Quasar.Frost 6 (Super).
    Golden Mask 4 (exceeded all expectations)
    Verator 5-4."
    Looking at his signature vlaser has built more than a dozen machines and likes this a lot
    Unfortunately I can't find which board version that he made
  • Orbit
    Sincerely nothing special !
  • pustareka
    best steel wire coil rx.tx. phase-tx. steel wire max.magnetica field. best deep. check wire compas. effect see noddle. big deppt steel wire windings. check self, big troth compass.
  • pustareka
    link ?
