Been looking on the md4u.ru site.
Seems some are having a lot of success using this with a small coil in amongst the iron and picking out tiny gold and silver.
Magnum on steroids!
i think this is corect schematicOriginally posted by crni1 View PostMy PCB still stands because I do not have the correct scheme.
[АТТАЦХ] 40814 [/ АТТАЦХ]
[АТТАЦХ] 40815 [/ АТТАЦХ]
but i cant garanted because my pcb doesnt work i was chek pcb with this schematic and everything is corect done with schematic
but i think something misig there
something mising i try a lot variant to fix but something was wrongOriginally posted by crni1 View PostMarkoram on my pcb is connected, I'm not done yet so I can not tell you what and how it works.
I had same problem when i conect pin 2 from coil on 47nf gm got just ferrous target, if i dont conect pin 2 gm works but on everithing geb and disk doesnt work correctlyOriginally posted by CDI View PostCan somebody show me pot and switch connection's for TH version? I have some confusion's, i have original coil for gm and got only ferrous target's.
there is picture how i conect coil
P.S.
coil is original detech sef 30x25cm for gm and works on 8 and 18khz[IMG]
[/IMG]
Originally posted by Nándor View PostGood, do you have an oscilloscope? with that it's easy. If you dont have try to adjust some how the frequency of the Tx coil so you get good phase angle between Tx and Rx. The oscillator drives the Disc and Geb sample circuits. Did you checked your components isnt there something wrong?
Instruments are there, collected more than one metal detector. TX +220 nf 12.3 kH, RX is nonresonant. I will experiment more ..
