Magnum on steroids!
  • ivconic
    Originally posted by Toros View Post
    Look for Express SCH. This program is author's favorite .
    Yes it is done in ExpressSch, part of ExpressPCB package.
    http://www.expresspcb.com
  • Toros
    Originally posted by joop View Post
    Okay, another question. Which program do I need for the sch files? I have tried splan viewer, P-CAD sch viewer and EAGLE. Neither of them work...
  • SVEN1
    I read some .6 program version files will not open .7 version files and so forth. Might be the problem.
    You can also try
    Files with sch extension are generally 3D schematics created and saved in one of the CAD programs.
  • joop
  • joop
    Thanks a lot Toros!
  • Toros
    And here is the third PCB.
  • Toros
    Mechanism to attach files works very slowly!
  • Toros
    Is this enough?
  • joop
    Can anyone make gerber files available? I don't own a copy of sprint. Thanks!
  • bandito
    No development for part list
  • bandito
    [QUOTE = From the model "1+" up to the model "4WD" it is all the same pcb.
    Except for some components added or removed from the pcb and front panel.
    Some front panel commands are "locked" with fixed presets inside the model "1+",
    while the same ones are presented on the front panel on model "4WD".
    According to this you may anticipate the rest of missing components.
    For example, for changing TX frequency between 8 and 18kHz, you need to add
    switch and two non polarized capacitors: 100nF and 470nF.
    "Auto GEB" is fixed preset inside with trimmer and "Manual" is with potentiometer mounted on front panel.
    Another switch is just switching between them.
    P.S.
    This is nothing new. This is quite old "practice" already seen at some manufacturers in the past.
    First what comes to my mind is the case of Minelab Musketeers: Colt, XS, Advantage...
    Pretty similar story...
    [/ QUOTE]
    Thank you ivconic
    You'll show you how to connect all options
    Auto GB and maunal and two tones
  • SVEN1
    I started to make up a parts list for the SMT PCB I am working on.
  • bernte_one
    was same Story on tesoro ยต Series, if you have a Compadre you can do with some mods the next higher detector in the model line
  • bandito
    The value of L3 what.someone there part list please?
  • ivconic
    Inside all 3 boxes is the very same pcb.
    Same story.
