No i don't have it. I haven't made it.
I did only skim component placement as sort of reminded, in case i get any of those on service.
I decided not to trace out pcb draw from model 5 nor to trace schematic because it has 2 programmed chips which we can not reproduce.
The rest of circuitry is more/less ancestor from previous models with slight changes.
But now thanks to ozzy_sv we have more complete details on model 5 too.
Honestly... i had model 5 for several days on testing and didn't like it much.
From whole series i liked most model 4WD.
Magnum on steroids!
chill out.Originally posted by Toros View PostMan!
Ivkonic gave us schemes and PCB for granted, and you want to take further and numbered items specially for you.
If that is so necessary - take it himself and then post it here for our convenience.
I respect what Ivconic did.
Read again what I have posted. I've asked if someone has already posted it, because it seems logical. I can do it myself, no problem.
Man!Originally posted by RH-Lightning View PostIs there a lay file for SMD board with numbered elements in this thread?
There is one with types/values. I guess the best option is numbered elements without values (so sneaky chinese don't copy it)
On some Golden Mask models there is no GEB potentiometer on front panel, on some model there is.Originally posted by ozzy_sv View PostHi
where is potentiometer ground balance ?
here there is no potentiometer of ground balance ?
or I do not see him, then how is tuning out from ground?
Generally the schematic i posted applies to all models the same.
GEB potentiometer can be wired directly to pcb instead R90... OR adapted with R90 and wired in series with it.
It's up to you to decide what suits you the best.
You can adjust R90 trimmer to reject hotrocks and minerals and leave it fixed on pcb (so called "automatic ground balance") or
you can wire multiturn potentiometer on front panel to pcb with wires.
You can put only one precise multiturn... or you can use trimmer and potentiometer in series too.
Make your choice, pick any of the combinations, it is up to you and your preferences.
Here is the GEB;
Here is the GEB pot.Originally posted by ivconic View Post[ATTACH]37743[/ATTACH]
"...R90= Audio pitch, audio frequency, also can be fixed value, according to your own preference..."
This is typo! It should be "R60= Audio pitch, audio frequency, also can be fixed value, according to your own preference..."
Hi
Thanks for the quick response! I have inductance 100uH and PC 123 too.
Seems i missed to post corrected one so far...Originally posted by Toros View PostHello Ivconic,
I begin to work on PCB "TH with.....". This board is easy to make at home. Constituent assembly is so compressed that I do not see how I add those elements that are omitted(missed). Maybe it had some of the resistors be provided for SMD assembly, to free space for other items.
I have several questions that I hope to receive an answer in the process. What are the data of the drosel L3 and who optocoupler is marked as 1522. Who else optocoupler can be used instead.
Thank you!
I did the previous one with those few components "in air" above some components.
Not that hard task, it's just few capacitors. As i recall pins 3. and 5. need 100nF to ground and there are few more components to add.
L3 is there to additionally filter voltage. You can omit it and put a wire jumper. Or put 100uH inductance (drossel).
I can't tell what exactly is 1522, haven't find it's datasheet. I put there PC123 and later on on another i used PC817.
Both are working, i can't notice any difference in behavior. Obviously not critical part.
Here is the corrected pcb design, done by one of my friends;Attached Files
Hello Ivconic,
Thank you!
