Target response tester
  • Ordered some metal sample packs to test other than foil. Tested the C110 copper sheet pack today, approximate 4x4 x .016, .021, .032, .04 and.0625inches. Recorded the data and didn't see 5 decay lines. Received (2).021, (2).04 and (1).0625 plate. Recorded the 5 plates stacked also. Plates have a .05mm plastic film covering them so not touching. Didn't know if %IACS would be close to 100. I have a 99.9% copper coin that calculates %IACS<100 with .06 multiplier and Carl had less than 100 with his test of 99.9% copper, reply#253 nugget simulation thread. Calculated TC assuming 100% and with multiplier .065, looks like .065 is to high or some other problem.
    Have a Brass260 and 6061 aluminum pack to test yet. Some .0007inch(.0178mm) and.00135inch(.0343mm)C110 copper foil coming to test. Not sure what will learn with the brass and aluminum packs, multiplier and %IACS?
    • You're really struggling with things , one minute too short, another too long....
      I'm tempted to have a try at testing straight copper wires, I don't have your sizes, but that shouldn't matter if I'm going to plot a straight-line graph. The problems I'm anticipating are: very short time-constants are harder to measure accurately; bigger wires, with longer TC's, WILL have skin-effect errors, that can't readily be compensated for. So ... what length copper wire did you settle on in the end?
      I've made a selection of nice '20mm' copper rings. Trawled through some big maths for inductance calculations ( which make no real difference ), and surprisingly, I get a pretty good agreement with the theoretical TC value. Well, for the modest sized wires, anyway. The chunky wires make nice-looking rings, that were hard to manufacture, but show very clear signs of skin effect.
      I'll hold back on the details, until I've sorted stuff out, but my measured TC's were +6% over theory. I've not allowed for solder-joint resistance.
      Attached a pic of the rings:
      • Originally posted by Skippy View Post
        Wire length for straight wire testing didn't effect TC after a few wire diameters(don't remember how many diameters but could test to see)Cut wire length for rings, 63mm(20mm diameter), 94mm(30mm diameter)or 126mm(40mm diameter). You rings look good. Did you start with a fixed wire length and then make ring? My measured was over calculated, solder joint resistance should make TC less than calculated. Including the chart with my 20mm diameter rings.
        Charted the other metal samples I got. I'll try a 100mm square of heavy duty aluminum foil tomorrow. Looks like .065 multiplier is to high for my tests today. Not sure about %IACS for 6061 aluminum and 260 brass but copper shouldn't be over 100. I'm struggling but maybe I'll figure it out. Still have some copper foil coming if foil is causing the problem.
        • For straight wire tests I was thinking, 19mm(3/4inch)
          • Temperature effect on target TC. Cut a piece 45mm square from one of the copper sheets reply#138. Covered one side with masking tape to aim infrared thermometer at for recording temperature. Heated target with a heat gun, placed target above coil and recorded four temperatures as the target cooled.
            Skippy, have you done any straight wire tests yet?
            • All my rings were made by measuring the correct straight length, then forming it around a plastic rod, then fine-tuning with pliers to get the ends matching. With the exception of the 2.44mm wire one, which was made 7mm longer on each end, the cut points scribed on. It was then bent on the former, and then cut /filed to the marks. The last 5mm or so of a loop is the hardest to bend, making it 'over-long' gets round this.
              I've since made two additional loops from smaller diameter enamelled wire, to fill in the gap at the bottom end. I'll try and locate some heavy gauge enamelled, it's in a box somewhere ....
              Yes, I made some 19mm long straight wires. The bad news is the thinner wire ones give too little signal to get any accurate measurement. I was also expecting the thickest ones to also give misleading readings due to skin-effect. However, I did get 4 points on a straight-line graph, and you won't believe this , but they match the equation:
              TC = 0.029 x %IACS x Diameter2
              Assuming Cu wire = 100 IACS.
              But I would prefer more points on the graph, and maybe if I used the 5" coil I could get better accuracy, so don't take the 0.029 figure as final.
              The two additional thinner rings behaved as expected, plotting all but the two thickest rings gave a measured value 7% over theoretical value.
              But..... I used a conductivity figure of 58 x 106 = resistivity of 17.24 x 10sup]-9[/sup]
              This is for annealed Cu at 20C . If I tested at 17C that makes theory TC increase 1.2%. And is Cu wire 100% IACS? It could be 101%, maybe higher? That would also increase theory TC by 1% . I will have to try out that fancy meter on a length of Cu wire.
              I'll post up the plots etc tomorrow.
              • And a quick straight-line plot of the temperature change on your test plate shows a decent fit, with the exception of the 61C point, which appears to match an actual temperature of 72C.
                (Plotting TC-1 against degrees C , straight-line at correct slope rate)
                • Some web info on copper wire:
                  In 1913, the International Electrotechnical Commission defined the conductivity of commercially pure copper in its International Annealed Copper Standard as 100% IACS. Furthermore, since 1913, processing technology has improved, to the point where copper conductors in electrical wire applications can exceed a conductivity of 100% IACS, even routinely reaching 102% IACS."
                  "The most common high conductivity copper for conducting electricity via wire, cables and busbars is Cu-ETP (Electrolytic-Tough-Pitch).
                  It has a minimum conductivity rating of 100% IACS, although most Cu-ETP sold today meets or exceeds the 101% IACS specification."
                  • I haven't completed my promised plots, as I wanted to get some extra wire sizes to fill in some gaps, particularly for larger diameter gauges. I have been successful , I've made three new rings and four 19mm lengths, and they are great fits, with the exception of the 3.00mm diameter '19mm' which is odd, more investigation needed on that one, but I don't think its pure copper, it seemed a bit 'springy'.
                    But the '19mm' TC values are excellent, a cracking straight-line, showing TC = 0.029 D2 %IACS , not a hint of skin-effect.
                    The rings also chart great up to about TC = 50 usec , where measured drops down vs. theory. I assume this is mostly caused by Resistance increasing due to skin effect, though Inductance is also slightly affected by it.
                      Looks like you are getting good results. 2mm wire is the largest I've tested, will get some larger wire next time to store.
                      What size wire were you using for the 50usec TC ring? http://www.geotech1.com/forums/attac...2&d=1547342322 chart I posted above, AWG#16(1.29mm diameter)tested about 50usec for me and showed some skin effect at start of decay.
                      • I don't have an actual 50 usec ring, that was just an estimate of the point where measurements start to deviate from a straight-line, and it's probably more like 45 usec.
                        The actual readings near that value are for wires of diameter: 1.23mm, 1.35mm and 1.58mm, measured and calculated values for these were:
                        D = 1.23mm ; Theory TC = 39.15us ; Measured TC = 41.05us
                        D = 1.35mm : Theory TC = 46.1us ; Measured TC = 47.7us
                        D = 1.58mm : Theory TC = 58.9us ; Measured TC = 59.05us
                        The best-fit line for the smaller-diameter wires ( up to 40us TC ) shows: Measured TC = 1.06 x Theory TC. This could be 1.05 if test temperature ( 17C ) was taken into account. But you can see the 1.35mm wire is dropping off, being 1.035 x Theory, and for the largest 2.44mm wire measured about 0.84 x theory ( 99.6us vs. 119us ).
                        I only have one really thick wire loop, the 2.44mm, the next one down is 2.01mm, the other 10 continue down to 0.46mm.
                        • [QUOTE=Skippy;252776]
                          /QUOTE]
                          Have you tried more wires side by side for a larger signal? Doesn't seem to effect time constant with my tester and amplitude adds.
                          • "try more wires side by side ?"
                            No, I wanted consistency - all my 19mm lengths are 19.0mm with filed flat ends. Besides, the smaller ones give little useful data, bearing in mind I'm plotting Diam2 , all the sub-1mm wires just crowd into the bottom end of the line. If anything, more wires in the 1.9mm to 2.3mm range would be more useful.
                            It also occured to me that consistency may be useful if they were needed for other tests, eg. signal strength measurements. I could also borrow a better meter from work if I wanted to measure the small signal better ... or knock up a x10 etc pre-amp.
                            • So here is the 19mm long wire test graph. Wire diameters used were:
                              1.10; 1.23; 1.35; 1.58; 1.73; 2.01 and 2.44mm
                              As the test was done at a temperature of 17C, I used a figure of 101% IACS in the maths. I assumed the wire was 100% IACS at 20C. ( I will have a go at testing some of the wire samples, to see if they really are 101 - 102% as some sources say )
                              Gotta say, it's the straightest graph I've plotted for a while , and I was expecting the fat 2.44mm wire to show some skin effect and spoil it.
                              Still, the end result is K = 0.029.
                              • And here's two graphs for the '20mm' diameter copper rings. One shows all of them, clearly showing what I assume is skin-effect ( 13kHz VLF used ), and one showing the smaller gauge wires in more detail, to show the decent straight-line.
                                Twelve wire diameters tested in total:
                                0.46; 0.57; 0.73; 0.83; 1.02; 1.10; 1.23; 1.35; 1.58; 1.73; 2.01 and 2.44mm.
                                All were bare copper electrical grade wire, the two smallest were enamelled.
                                The 'theoretical' figures assume conductivity is 100% at 20C ( 58 x 106 ). The tests were done at a temp of about 17C.
                                The slope for the smaller gauge wires is about 1.065, ie. 6.5% above theory. 1% of this is down to temperature, so it's really 5.5% above theory.
                                The other 'errors' I've discounted. The solder joint is maybe 0.1mm thick, roughly equivalent to 1mm of copper, so the loop resistance is increased by (63+1)/63 = +1.5%. But if this is wire with IACS of 101 - 102%, that roughly cancels the solder-joint resistance.
                                Theoretical inductance values are estimates, but seemingly pretty good ones ... I'll post more about this later.
