Good experiments Ivconic
Driving a JFET from a micro
I think there needs to be an intermediate drive circuit between the micro and ordinary power mosfet for voltage level. I was looking at the Cscope schematic at the beginning of the thread and comparing it to the HH2 tx drive circuit.
Originally posted by dbanner View PostI think there needs to be an intermediate drive circuit between the micro and ordinary power mosfet for voltage level. I was looking at the Cscope schematic at the beginning of the thread and comparing it to the HH2 tx drive circuit.
Take original Barracuda, pull out CD40106 and attach Arduino UNO with wires on its place, it will work just fine.
I did that in the past. Checked.
With notice; GND from Arduino goes to Barra's -5v and +5v from Arduino goes to Barra's GND.
You don't need to change anything else on original Barracuda pcb. It will work fine.
I am trying something bit different here. To include Atmega, 2-stage RX and 4053 switching on the same pcb.
So some changes must be done. Half success so far. It works, not having good "depths".
Probably bad timing.
I've been opening up lots of old phone charges just because I have a lot of them lying about the place useless.
Now I've noticed that most of them contain optocouplers. 4 pin jobs, anode,cathode,emitter, collector.
I was wondering if these could be used to drive the mosfet from the pulse provided by the micro.
Here is the datasheet for one from a typical phone charger. Perhaps two could be arranged in totem pole configuration.
The idea is to experiment with otherwise useless components which can only be put in the garbage pale.
Maybe the transients are not suitable on this one.Attached Files
I've been tearing down old PSUs and salvaging components as well. The optocouplers I've found so far are the JC817 like yours, 4N35 and PC123. What they all have in common are rise/fall times and propagation delays in the microseconds range. For example the 3 μs typical 18 μs max fall time on the JC817. Surely too slow for controlling sampling or driving the TX?
Originally posted by Cazavor View PostI've been tearing down old PSUs and salvaging components as well. The optocouplers I've found so far are the JC817 like yours, 4N35 and PC123. What they all have in common are rise/fall times and propagation delays in the microseconds range. For example the 3 μs typical 18 μs max fall time on the JC817. Surely too slow for controlling sampling or driving the TX?
There are however high speed optocouplers, like the 6N137A which boasts of rise and fall times in the tens of nanoseconds range. Surely these are fast enough to do the business.Attached Files
Here is a document which describe a means of improving the rise and fall times of optocouplers by cascode method, which I think can be used to implement a faster VCO response with these general purpose optocouplers. Maybe of interest.Attached Files
It works slightly BETTER than with CD40106.
And much more cleaner!
Watch the new video i just posted here:
https://www.geotech1.com/forums/show...136#post269136
Originally posted by dbanner View PostThere are however high speed optocouplers, like the 6N137A which boasts of rise and fall times in the tens of nanoseconds range. Surely these are fast enough to do the business.
I tried the TLP250 and they worked as well as the FOD3180/ IX3180, but minimum supply voltage is 10V. The datasheet says they are used in air condition and heating systems which means you might find some in the junk pile?
https://www.google.com/search?sxsrf=...w=1280&bih=604
Originally posted by Altra View PostI tried the TLP250 and they worked as well as the FOD3180/ IX3180, but minimum supply voltage is 10V. The datasheet says they are used in air condition and heating systems which means you might find some in the junk pile?
