Need pinout coil in pcb whites coil gmt gold master
    Thanks mr carl . I think there are Diffirance in africa version of gmt gold master e series .in main board and coil .
      https://www.detectorprospector.com/f...ters/#comments
        https://www.detectorprospector.com/m...r-gmt-rebuild/
          The same with coil connector
            [ATTACH]55959[/ATTACH]
            Invalid Attachment specified. If you followed a valid link, please notify the administrator.
              No, same circuit & coil, except for a while the 5.3 was unique to Africa.
                Hello mr this is coil inductance . Click image for larger version
ID:	361929Click image for larger version
                Whay the tx is 90ohm ?
                  use thermo fan air desolder gun for the whites yellow glue deleting. you will find some components... there might be 'capacitors and a resistor' inside invisible for you.
                  do some research of coil, because it is in YOUR hands, not mine.
                  maybe this https://www.youtube.com/watch?v=hLbDUdaFWKA
                    Thanks kt15 my be later . I will try that later . I want to make a large coil for this unit but what about components inside the coil ? The same or not ?
                      To add to Carl's post 5
                      Notes I made from a Whites GMT eliptical coil
                      Tx freq 47.6khz
                      RX 3.0mh 16ohm
                      RX PIN 1 clear center
                      RX PIN2 shield
                      TX 2.75uh 2.55ohm
                      TX Pin 3 shield
                      TX PIN 4 red center
                      In parrallel with TX coil is 33nf + 2.2nf + 470pf.
                      Not sure if each coil was custom tunned or all coils had these values?
                        Have you inner or instruction to diy 14 " .10" .or 18" coil
                          Tx freq 47.6khz
                          RX 3.0mh 16ohm
                          RX PIN2 shield
                          TX 2.75uh 2.55ohm
                          TX Pin 3 shield
                          TX PIN 4 red center
                          yes, custom tuned of TX coil sure to 48kHz. those additional '2.2nF + 470pF' are set just for accuracy of the tuning in resonance.
                          anotherway you get a distortion of TX signal.
                          the forum has the data of coils. a pic.
                            Hmmmm! The material (KT315) posted is accurate with Whites factory material... I was not aware it (48 KHz coil data) was out in the internet! KT315 posted material has additional data added to Whites factory material. Now factory original material was drawn by unknown Whites engineer, who I believe was John Earle him self! John Earle back then had left Compass Electronics before its demise, after creating Compass Electronics models AU52, AU2000, Gold Scanner Pro, and Gold Scanner units, and then became Chief Engineer for Whites Electronics.
                            Thumbs up KT315! It has added to Whites Electronics factory drawing more excellence...
                            Melbeta
                              Thanks to all .
                                Tx freq 47.6khz
                                RX 3.0mh 16ohm
                                RX PIN2 shield
                                TX 2.75uh 2.55ohm
                                TX Pin 3 shield
                                TX PIN 4 red center
                                Hi altra did tx is 2.75 uh . Or 275 uh ? And what sp?cification of tx insid ?
                                And my coil is only 33 nf +2.2nf
                                And risistor between tx outsid and tx insid .
