Induction Balance Stuff - Single/Multi Frequency Response, GB, Disc, Measurements, Ideas, Fun, etc.
  • boilcoil
    Thanks, Taktyk.
  • Taktyk
    Originally posted by boilcoil View Post
    Hey Aziz,
    I don't want to spam your topic, but if you want fewer errors and bugs - use Python. It is the most well-known language in AL. If you are interested in why LLMs make errors - read the attached article. It is useful mainly because it gives you guidelines on how to proceed most usefully with AL and what to expect from it.​
    When you ask an AI for code in a popular language, the model has thousands of examples to rely on. However, when you ask for something in IBM APL2 (a niche language) or EES (a specialized DSL), the AI tries to 'guess' the solution by applying patterns from popular languages for instance, inserting FOR loops or IF-THEN-ELSE blocks where they simply don't belong. This is a classic example of hallucination based on statistics rather than a deep understanding of syntax.
    In the case of languages like EES, where the logic is based on systems of equations rather than sequential assignments, the model gets lost because its training, which is based on sequential code, 'doesn't know' how to think in parallel. This demonstrates that LLM architecture has inherent limitations that cannot be overcome simply by adding more data.
    If you are not an expert, you won't be able to detect that the AI has provided 'useless but plausible-looking' code. In niche programming, AI can become a 'machine for creating technical debt,' generating code that might compile, but doesn't solve the problem as intended.
    Perhaps the future does not lie in large, universal models (like GPT-5 or Claude), but in smaller, specialized models (Small Language Models – SLM) fine-tuned on precise technical documentation and constrained by specific syntax (i.e., constrained generation).
    As for metal detectors, this is an extremely narrow field; there are very few projects on GitHub. My experience shows that while LLMs can statistically relate to general concepts, they make a multitude of fundamental errors - for example, confusing TX frequency with ground filter frequency in Hz.
    While it is possible to find your way in general DSP-related tasks, knowledge regarding Metal Detection (MD) processing is virtually non-existent in these models. My work with these models over the last month has exposed everything. If I didn't have years of experience, knowledge from patents, and insights from relevant posts on the Geotech forum, using an LLM to search for information would have been completely pointless.
  • boilcoil
    Hi all,
    I'm so fkn fkn fkn hell disappointed.
    Hey Aziz,
  • Aziz
    Hi all,
    regarding LCR Meter implementation with AI help:
    I have installed the Google Chrome browser. Claude Code is running there.
    Claude Code is still making bugs but it can fix it.
    "Fix the code" Claude!
    There is a new artificial intelligent (AI) artist in the world:
    "Claude Money":
    It want's me to upgrade to the pro version. Or I have to wait several hours before I can go on.
    Anyway, "Claude Money" makes me more happy.
    Cheers,
  • Aziz
    Hi all,
    my new set of WIMA FKP2 capacitors came yesterday.
    I do have now a lot of low capacitance values from 33 pF to 1nF. I can test the mono coil VLF with extreme high Q LC tank soon.
    My PeakTech LCR meter isn't able to measure the D and Q of the FKP2 capacitors. D is showing 0.000 and Q above 2000 won't be displayed even.
    Some values have Q up to 1000 or lower.
    I hope, my Sound card LCR meter will give me more reasonable values for D and Q.
  • Aziz
    Hi all,
    Claude AI isn't obviously down. It isn't working in my Firebox browser anymore. Who has made the bug?
    I can't really believe it! Maybe the AI has fixed the code.
  • boilcoil
    Hey Aziz,
    Why are you surprised? AI (LLM) is a statistical processing model. It cannot calculate, it cannot think. It cannot self-learn, it cannot change itself, it cannot expand its capabilities, it cannot use the global network in real time, etc. It can only generate the best option in the transformation of the input to the output. The only thing it can do (this is the basis of its training before its release,when a model is still open, before it is "frozen" ) is - "Find which is the next token and continue the logical chain".
    AI is a great tool. It is no coincidence (I think it was Moodz) that it was compared to the discovery of the wheel. However, in order to be able to use it, you must take into account all these specifics. I think that in this regard Moodz is the best.
    The worst thing, however, is that LLM is not updated at all, it is simply replaced with the new version of the model, which is trained in a better way. However, upon replacement, nothing else is inherited except your personal preferences stored in your "personal long-term memory" - so the work done with LLM_V1 will not be transferred to LLM_V2 and will probably lost.
    Therefore, use AI as much as possible, don't get angry with it, and never trust it without reservation.​
  • Aziz
    Good news!
    AI (Gemini and DeepSeek) failed totally to make me happy.
    Wrong calculations, wrong calibrations, wrong results, ...
    Even if I ask the other AI to fix the bugs.
    For such a simple and trivial task.
    Complex numbers does not mean it is a very very complex task and calculation.
    I can't really believe it.
    A.I. = Artificial Idiocracy
  • Aziz
    Hi all,
    regarding complex LCR-Meter with AI help:
    I have tested DeepSeek AI first time. It is generating a nice C-Code. But full of bugs. I am not happy yet.
    Claude Code is down at the moment. And it isn't finishing the job due to limit arrive.
    Google AI is still making lots of bug. But you can ask for fixing. Ask for finding bugs. Ask for to be very very sure for correct implementation. Ask again. And again. (Up to dozen times).
    I have to built-in the code and test it.
  • Aziz
    Regarding the very important tips from AI:
    - Complex division:
    I have changed the function by a numerically stable complex division according to Smith (1962) against overflow/underflow​. This is absolutely required for the new LCR meter implementation.
    - Phase relation may get lost by averaging filters (like EMA):
    Vref, Vdut are measured complex voltages from line input. I walked into a trap by my latest changes on LCR meter implementation and was wondering about the measurement errors.​
    Don't do any Vref and Vdut complex averaging before calculating results. The phase relation gets lost or gets changed by the averaging filter. And hence the calculation of LCR measurement.
    Filter the calculated result only (Zdut and hence L,C,D,Q,Rs,.. derived from impedance Zdut).
    Does this has an important impact to the ground balance procedure too (projection method)?
    Still needs to be checked.
  • Aziz
    Hi all,
    after rewieving my old LCR meter code, I'll let the AI to code for me this time.
    AI is capable to do it in full complex math with I/Q decoded vectors (measured complex voltages Vref, Vdut).
    The AI gave me really very important tips too.
    I also want a 4-step calibration feature (Short reference, DUT open, DUT short, DUT load - another reference load) to get maximum accuracy this time.
    I want to measure the real loss of the FKP2 capacitors (BTW, not arrived yet).
    I have to code the GUI for the changes yet.
  • Aziz
    Hi all,
    my new FKP2 capacitors didn't arrive. It will take some time.
    But I'll rewrite the LCR meter code and finish it. And I will write mode code until my capacitors arrive. Or make a new mono coil.
  • Aziz
    Hi all,
    I have found my 0.1 % precision reference resistors now. I can use my own sound card LCR meter implementation for much more accurate dissipation factor (D) and Q measurements for the capacitors. Interesting, that I can also measure the input impedance of the sound card input line (Zp) by the calibration procedure. This is really frequency dependent.
    I have made my own small value capacitor with copper foil: C=140 pF, D=0.03 (3%), Q=33 @ 10 kHz, this is bad and has big losses due to the bad insulation material used.
  • Aziz
    Hi all,
    I have finally ordered a lot of WIMA FKP2 capacitors for approx. 100 bucks, total 360 capacitors. Pity, but not all values were available. Paralleling will do it either.
    And I have found a lot of long ribbon cables at home. I should make a big mono coil with it. Paralleling 8 or more cores together will still form a good HF litz wire alternative.
    Cheers,
  • Aziz
    This is the LTspice simulation:
    Simulated on the same resonant frequency.
    I have even disconnected the measurement ports.
Name:	2026 Dual-Frequeny Mono Coil VLF - same TX coil copper weight.png
