I have found another TX coil in my old box. No enamelled copper wire this time. It should withstand high voltages up to 600 V. Pity, the copper litz wire isn't tinned.
TX: L=440µH, R=0.3 Ohm.
I have reduced my shunt resistor to 250 mOhm due to power efficiency considerations. I don't have any low TCR shunt resistors (low TCR = low Temperature Coefficient Resistor). I have used 4x 1 Ohm parallel metal film resistors.
Now the transmitter is 20-30 times more quiet. No sparks between the interwire windings of the TX coil anymore.
Nevertheless, the bare enamelled copper wire can still be used for high voltage uses. As Spider-Web formed TX coil. Between the winding-to-winding sections, the voltage difference isn't much. Enamelled copper wire should withstand this voltage. Coil leadings and cables need thicker insulation however. The coil would weigh less.
I would like to use such a coil as I still have enough enamelled copper wire.
The RX coil isn't critical. Enamelled thin copper wire is enough. The RX coil won't see the high voltage due to inductance balance configuration.
Cheers
No joke this time.
