TESORO GOLDEN SABRE
  • mayky
    BF245C ?
  • FatBob
    Well from this; https://www.fairchildsemi.com/datasheets/J1/J105.pdf the big difference is Gate-Source Cut-Off Voltage.
    J106 might work if your voltage is in range;
    J106 -2.0V to -6.0V
    J107 -0.5V to -4.5V
  • Nandor
    Hello to all, can somebody tell me if I can repleace the J107 transistor with other J's like J105 or J106? On TME.eu there is no J107 only 106-105.
  • kt315
    yea. you can take TX part from Troy shadow x5 kinda like as 'universal TX generator' and use any VLF coil.
  • bernte_one
    you can use ts800 or ts1000 coil for muski (rx1mH / tx10mH)
    but you have to assemble an additionel pickup pcb on your tgsl pcb (the minelab coil Oszillator)
  • kt315
    TGSL will work with a coil without a capacitor inside on TX winding. ie tesoro uses SIMPLEST construction of a coil - NO RESISTANCES
    NO CAPS.
    whites coils WITH THE capacitor in TX side are not fitted tesoro schematics. really THIS CAPACITOR IS THERE, IN TGSL TOO, BUT in THE TX generator, as THE PART of IT. CAP IN BOTH CASES set THE FREQUENCY OF A DETECTOR just cause L * C gives THE (F) VALUE,
    KILO-HERTZ.
    so Muske... has or not the capacitor... no data... ABSENT. minelab often uses PREAMP in their coils.
    NO DATA there is the preamp in Muske coil or not.
  • seadoggy
    one ukrainian asked me to give him a front panel pic that I have not. his shield has waded off in time of long
    hunting. can anyone share it? in format Front Designer 3.0, jpeg or gif no difference all will be appreciated.
    TIA
    [ATTACH]34418[/ATTACH]
    Can i use Musketeer coil with TGSL board??,
    long time i read here i must use small pcb made for Musketeer coil but i cant find here.
  • kt315
    TIA
  • siimkuningas
    good work
  • paku
    this is my video before i sell it hahahaha
  • Koala
    Originally posted by pigeon View Post
    Thank you WM6
    info on coil here
  • pigeon
    Thank you WM6
    What Google translate say:
    hi all
    this is the first time I manufacture a VLF coil. I beg of you all to kindly help me, cause I really do not know how to do
    thank you all
  • WM6
    hi all
    c'est la premiere fois que je vais realiser une bobine vlf . je vous prie tous de bieb vouloir m'aider vraiment je n'est aucune idée
    merci a tous
    hi all
    thank you all
  • Qiaozhi
    hi all
    merci a tous
    Please read the forum rules, and make your posts in English.
    Basic Rules of the Forums
  • pigeon
    hi all
    merci a tous
