TESORO GOLDEN SABRE
  • siimkuningas
    Steel box is really not good environment for metal detector. You should hear what happens in kitchen, nonstop screaming outside i can play baseball with it and tell you if there was any metal inside the ball.
  • paku
    nice but i think better you try go outside in land and test stable or not
    cos i hear sound when you touch the handle
  • siimkuningas
    https://www.youtube.com/watch?v=YDDo...ature=youtu.be Not the best video but still something . Plug in any car fm transmitter(this one was 9euro in local shop) and works. Yellow numbers are my lithium over discharge protection Have to check it from time to time. Easy to fully charge as many batteries as you can carry or buy and take them with you.Got those green ones from makita drill battery. Had to build charger also. There is very slighty hearable continuous noise in sound, nothing serious. (must be set as mono or you can hear whistle, not loud tho).No delay in sound. But i can say my metal detector has a remote!!
  • siimkuningas
    I can do that(edit:tomorrow), but coil is still not finished.(sanding and need to bring mV down by 2) Living in a city, tools and workrooms at countryside.
  • paku
    can you show the video of TGSL with FM transmitter
    its look fun
  • siimkuningas
    Wooden stick, i had one that fits right into crutch and PVC pipe. Coil is connected to pvc, so length is adjustable. Pretty well balanced, i can hold it with just 2 fingers near fm transmitter and angle stays right.
  • Koala
    Originally posted by siimkuningas View Post
    thanks for answer. finished my tgsl some weeks ago. This thread made it possible. works pretty well with fm transmitter. Was a nice puzzle to solve for a person who bought his first multimeter 2 months ago.
    Picture before coil sanding and some other small "still need to do"-s http://www.upload.ee/image/4878141/DSC06058.JPG
    Good job. Well done.
    What did you use for a stem.
  • siimkuningas
  • Koala
    Is it possible to discriminate bigger pieces of aluminium?
    Not really. If you discriminate large aluminum almost all other targets will be discriminated out also.
  • siimkuningas
  • Sacchetti
    Originally posted by paku View Post
    ok thanks
    but this version is working ?
    The version 1265 is working as the others.
    Can be was revised after but you can check it directly on russian website.
  • paku
    hi who have sell TGSL Working Coil in here
  • paku
    ok thanks
  • Sacchetti
    what version eldo you make can you share
    I have done the version 1265.
    ATTACH]33191[/ATTACH]
    But I think it is not correct to speak of Eldo because this is a thread relative to TGSL.
    Therefore, please consider this answer only a parentheses.
    It is better to ask info about Eldo in one of its threads.
  • paku
    Originally posted by Sacchetti View Post
    I do not have built TGSL but only Eldo relative to tessoro md.
    Before and after I have built others md with technology PI, BFO and PLL.
    Can be I will do also TGS in the future, in this case I will propose my video.
