Originally posted by metaldetector107
the shield you can also not tape... but I usually do... what's important is that the shield foil will not move relative to coil windings, so stay all very strong and fixed... the best is , always, epoxing everything when the coil is made and shielded properly... that way the epoxy will block any further movement.
The pole is plastic: OK check if strong enough... must not flex when you swing the coil...
The nuts are few so I think all ok about that.
The control box is metal so must stay at least at say 60-70cm from coil (more is better cause will influence less the coil in case of vibrations). If you cannot stay too far with it... use a plastic made box if possible. All metals are a problem in control box cause the box is big object and not too far from coil (it stays in the detection range... so must stay very fixed relative to coil or at vibrations you'll get a false signal).
That's cause tgs/tgsl is very sensitive and if can detect a coke can at such distance easy (60/70cm) can detect also the movement of metallic control box. So stay far with it and very tight fixed or use plastic.
Kind regards,
Max
