Originally posted by Ultimate_Haze
It would be good to see photos of all your coils, along with:
1. TX, RX Dimensions
2. TX, RX Inductance
3. TX, RX Resistance
4. TX, RX Wire gauge/thickness
5. TX, RX Shield arrangements.
Ok -- 27 cm is not bad of course, but 30 cm is nice, especially if audio is "fat".
Why one 19 cm coil good??? But not GB??? This is important mystery! You have some useful experience now. Maybe we can get some insight.
Q: what do you mean "cannot ground balance"? How do you test ground balance?
Q: only one 19 cm coil good? What about other two?
I notice with my TGSL that target signal in GB channel is very small compared to Disc channel. Perhaps with some coils GB channel signal is bigger, more like Disc channel, and audio is better, because both signals needed to make audio.
Possible explanation: If target phase becomes shifted so it overlaps both the disc and GB sync pulse phase more evenly, then maybe makes more sensitive detector -- but destroys GB control.
This could happen if the RX coil resonant frequency is not normal distance from oscillator freq, or the the RX coil resistance is changed causing the phase to shift.
But I don't know. I have tried to vary those parameters, but no good conclusions yet.
-SB
Exactly!
