As I have stated before in another thread, I have aquired a 1265X that is somewhat distressed. It had been swallowed/drowned in brackish water by hurricane Ike.
Initial checkout revealed all potentiometers (Disc1, Disc2, Volume, and Sensitivity) need replaced. Speaker, mode switch, battery check switch, coil connector, headphone jack check out serviceable. PCBs look pristine.
Oops, someone has soldered a wire to pin 4 (-4V, chassis gnd) of the PCB edge connector. The wire has a paper clip soldered to the end. To what end, I do not know.
Removed all controls from front panel, separated PCBs. Hooked up 8 cell AA rechargeable battery pack to pins 7 & 8 of ribbon cable socket. WE HAVE LIFE!! Well, sort of. Voltages are acceptable (-3.96V & +3.89V), so power supply/voltage regulator working. Without coil connected, the TX oscilator output is 81kHz and unstable. With coil connected, TX signal looks terrible. Only abot 3Vpp; very unstable looks like 4kHz & 5kHz intermodulation.
Troubleshooting with coil disconnected reveals same signal on pins 1 & 2 of U101 (LM339). With coil connected pins 1 & 2 look like outputs are ored together. Removed and replaced the LM339. Fired back up. Oops, no output; Positive rail at 5.8V, negative rail at -3.98V. Inspect my solder job and notice excessive flux on board and LM339 pins. Off to the sink; scrub the board gently with small brush, soap, water. Rinse and let dry.
Fire back up. Violla! We have a stable oscilator oscillating at ~77kHz. Oops after about 1 minute, oscillations become erratic; Positive rail is 4.5V and increasing. Re-inspect and see that a couple places are still damp. Let sit and dry for 2 hrs.
Fire it back up. It works again! Rails are -3.96 & +3.89. This time everything remains steady for more than 5 min. Decide to hook up coil. Fire it back up. Tx signal looks super! Nice clean sinusoidal 12Vpp signal.
Now to check out Rx. The demodulator gates look good. Output of pre-amp is about 100mvpp and is very near to in phase with TX (coil in air). Iron taken near the coil causes the phase to remain the same and signal increases. A quarter brought near the coil changes phase, decreases signal level; As it is brought nearer it shifts phase past 180 degrees and then increases in level. It appears that Fisher coils are not nulled in signal level (there is a 15 Meg resistor connection between TX and RX coil in the coil head) at the input to the preamp. I suspect that the coils are nulled without the 15M connected. The resitive channel demodulator output is null when no target present. The Disc channel demodulator output is negative with no target present.
The static channel, resistive channel, and 1st stage of Disc channel all check out.
Cannot check out remaining circuitry until I get some replacement potentiometers.
THE BEAST IS COMING TO LIFE!!!!
To be continued...
To be continued...
