hi every one i purchase this device for treasure huting in 2003 but now coil winding has been damage
a power_full metal locator
metal locator
there are two 9 volt battry DD coil 7inch any one has a schematic ..
metal locator
hi every one there was 42 inch senstivity at a medium object.......
metal locator
hi any body send me schematic ....
a power full metal locator
Hello Rajesh , Looks like a Fun and Great Winter Project !!! It seems like a VLF DD search-coil . Only 2 IC chips and 3 transistors on main circuit board . Let us know how it Goes ?? What are the chip numbers . Might be low frequency , with an oscilloscope you can find out the exact operating frequency . I heard of Detech brand somewhere , Maybe made in the U.K also ??.............Regards.............Eugene52
metal locator
hi eugene there are a small 8 pin ic lm 358 and - cd 4016 b transister bc 547 i will be send all component list if you need .....Originally posted by Eugene52 View PostHello Rajesh , Looks like a Fun and Great Winter Project !!! It seems like a VLF DD search-coil . Only 2 IC chips and 3 transistors on main circuit board . Let us know how it Goes ?? What are the chip numbers . Might be low frequency , with an oscilloscope you can find out the exact operating frequency . I heard of Detech brand somewhere , Maybe made in the U.K also ??.............Regards.............Eugene52
Hello , I bet the problem is with the tiny circuit board inside the search-coil and not the windings . There are a lot of circuit tests you can make with just a good ohm meter . You might have a Good Rare VLF Machine that not to many people know about !!.....Keep us informed on your interesting Old Circuit....................Thanks................. ..Eugene52
No need to be very complicate for to be sensitive.
Is the 8 pins IC a LM358 and the other a 4066? Appears use zener for volt. regulation... seems like a C-Scope model with some variants.
Do you can trace the transmitter circuit inside the coil housing?
Esteban
rajesh: most probable in damaged is the oscilation transistor, (in coil tx), because these suffer extremely work
may be esteban know the solution to these faulth
try the oscilation of tx ( little circuit in the coil ), try the signal to finish the second trasistor of receptor
i am not expert tegnic, but beginer
dman
metal locator
hi detectoman here is anything damaged only coil circuit working well any way currently i no need that i has many more detector gary's pi ------- hammerhead ------- thanksOriginally posted by detectoman View Postrajesh: most probable in damaged is the oscilation transistor, (in coil tx), because these suffer extremely work
dman
