formerly known as 'project oberon' and now patent pending ...
First posted http://goldprospecting.invisionplus....specting&st=60
Pulse Induction Metal Detector Having a Sinc(x) transmit waveform.
All metal detection systems I have seen transmit some sort of pulse or continuous waveform. The sinc pulse is the missing link ( or is that sinc
) between continuous and pulse systems. It is the basis for the design of a detector that transmits pulses yet the analysis is in the frequency/ amplitude/ phase domain ... nothing new here ... however all current designs have been doing it back to front. A square or rectangular pulse in the time domain has a sinc(x ) ie sin(x)/x characteristic in the frequency domain. However if you transmit a sinc(x) waveform in the time domain you get a rectangular or square response in the frequency domain.We are still transmitting 'rectangular pulses' but in the frequency domain ... rather than the time domain and every frequency component of that pulse has equal amplitude and known phase. So you have the synthesised equivalent of thousands of parallel detectors in the analysis. In my reference design there are 4096 virtual parallel detectors working from DC to 86 Khz in equal incremental frequency steps. The nature of the sinc(x) waveform also removes one problem that PI detectors have ... the back EMF. Because there is no sudden transition in the waveform ( there are some constraints here ) we sample under the transmit pulse waveform and by subtracting the transmit waveform ( because we know what it is ) from the received signal we can see the full pulses from the targets and ground .... what would be a comparative paradigm shift in technologies ? .... think of your old 56k modem vs ADSL .... sinc(x) technology based detectors would be the ADSL.
moodz
moodz
