WARNING! VHF ringing
If you notice excessive heating of the MOSFET, it may be due to the VHF ringing because parasitic capacitances and inductances form Colpitts oscillator circuit . The VHF ringing is difficult to monitor with oscilloscope, but you can hear it with a FM radio. This effect is known to Ham radio designers using class C MOSFET amplifiers. To avoid ringing at turn off process, they connect one 10-20ohm resistor directly in gate lead of MOSFET. When two or more MOSFET are connected in paralel, damp resistor 10ohm must be connected directly to each gate.
At the time interwal when MOSFET or VDR or ZD is conducting because of breakdown , the energy accumulated in L and in both capacitances is dissipated as heat with great power, because in the formula for power P = Vz.I,
voltage Vz is great. When the zener current stops, the rest of energy dissipates at a maximum rate if the ratio between the resistors corresponds to the published above formula.
CONCLUSIONS:
1. The oscilloscope connected to resistor Rm can not measure this part of coil current that flows through coil's stray capacitance C.
2. The designer should take measures to reduce not only coil capacitance, but also TX networks capacitance.
3. When you measure resonance frequency of coil, dont disconnect it from TX network.
4. If the measured resonance frequency is too low, reduce coil inductance, but this reduces ampere-turns of TX coil.
CONCLUSIONS:
