Jeohunter - Visual Ground Scanner
  • loading cable & accu batteris
    hello my Friend Fun Finder this are the picture you ask of the new accu pack that i build and don't have enough volt and the loading cable the charger privides and with the setting set set of the device . volt output li pro charger only have 5.A and the volt current 3,6v(1s) 7,2v(2s) 10,8v(3s) 14,4 (4s) 18,0v(5s) 21,6v(6s) and AUTO the capacity cutt off can be setting 10mah -20mah over
    i hope you can guide me my friend thanks
    geo-i
    • Hello Funfinder
      The land owner said eatch diged holle containce one plastic drum, in total land there are three drums. one contain some gold item also. in the plastic drum full of paper metireal how can jeohunter find it as a cavity? total diged lenght is 7 feet, in this drum size 4 feet, so only 3 feet abouve the surface it is available. so now you pridict it is possiable to find?
      • hi geo-i my good partner!
        I created a diagram for you. good luck!
        Your charger has enough power for single cell balance charging.
        this way you also will get the best performance and power.
        The voltage difference is no problem, you will measure more
        voltage if the accus are connected at the charger and almost full.
        If you cannot set it to 3000mA manual while balance charging
        set it to AUTO cut off at 10mAh over.
        But usual this is for
        NiMH only. Li-Ion loading has a cut off if the power has
        reached 4,2v.
        short info:
        - solder cables at your accu-pack with useful contact for the
        balance charging connectors (2times 5 cables and connector)
        - switch on the charger and set to li ion balance auto or 3000mA
        - connect correct cables with the plugs for balance charging
        Start at the (-) (PIN1 or Pin6) and use the 4 following plugs left.
        - wait around 1h until the first 4 accus are fully charged and
        then connect the other 4 accus and load them, too.
        Have Fun!!!
        • hi syed ayub basha
          First please tell us if your Jeohunter now is working.
          Do you know how large is the site in meters (x,y)?
          And the diameter of the upper side of the barrels?
          3 barrells will raise your chance to find them and the
          new depth of only 3feet below the surface makes it shure those
          are detectable!!! Now this is very easy... if you find the right spots.
          You are very lucky !!!
          This has to do with the mineralic ground around the barrels.
          The mineralic stuff and the salts in the ground have a strong influence to the Jeohunters detection balance adjustment you can achieve by correct ground balance and the reset button.
          The strenght and detection patterns of the EMwaves will change if solid mineralized ground ends and the coil is above a large barrel with air, gas or paper, doesn't matter as long it's not the same mineralized as the soil around. Even if the barrells are 3ft below a volume of 100 liters will create a big change of the coils EM-field, which has a effective radius of 5-10 meters.
          You can compare this with the Multi-Sensors you can get in Do-it-yourself-Homeworker-Markets - also called stud-finders.
          If they're set to brickstone you can detect wood or metal inside the wall because this materials create different EM-field strenghts.
          Of course the Jeohunter is much more powerful.
          btw. how many coils do you have?
          You also can find the barrels very good with the 1m coil!
          • Mr. Funfinder
            To day i came to Hyderabad. along with my jeohunter here we test and balance the jeohunter first. when it balance it is OK. i have total 3 coils. with 3D jeohunter. i go to my place and again do the ground balance. then i start my work. seller of my new jeohunter is in Hyderabad. so he ask to come here. that's way i came . OK. for your guidance. can i dig one hole and put one barrel and do the test. after i check original place? how it is?
            • thank you
              hello my best friend fun finder thank you very much for helping anyway for good luck for you and all joehunters metal detectors teresure hunting out there
              geo-i
              • Hi syed ayub basha,
                I am happy your Jeohunter is good working and you now know how.
                And it is very good you have all 3 coils.
                Next step is to get more and more search-experience.
                This was very good idea you have!
                I would bury a 10liter plastic bucket first directly at your treasure hunting site.
                This is not much work and you can get alot experience and the best ground balance!!
                Dig an 1.5 to 2 ft. deep hole and place the bucket upside down. If you like you can fill it before with old newspapers.
                Close the hole and stamp the soil compact.
                Next try to find the bucket by the Jeohunter. You can test at what ground balance value and sensitivity you will get the strongest signal and if you get cavity or metal signal.
                Yes, you also could get a "positive" signal (normally used for metal)!
                Because the soil around the bucket has an effective higher mineralisation value than over the bucket. This depends if the ground balance is higher or lower than the "objects value" you are searching for or at and the internal detection algorithms of the Jeohunter.
                But don't worry.
                If you have good experience and found out the best ground balance plus sensitivity value to detect the bucket with biggest possible signal strenght you are ready for the huge barrels!
                If the soil is not very strong mineralized (quartz sand as example) you have to use very high sensitivity and moving the coil very close over the ground.
                If you have been successful with the 1,5-2ft. bucket test and got very good detection signals and enough experience you may try to bury it at 2-3 ft. This way you can get at the very borders of detection capability. Try to use the medium standard coil and also the 1m so you can find out which coil is better in such a special case.
                And as a somehow reference-test look for a metal plate or pan with the same diameter the bucket / barrel bottom has and find out from what distance you can detect it in air. You will get here more "depth" because of the much higher "contrast factor" between electromagnetic-powerful metal and air compared with the cavity but this is only for getting yet more experience.
                Do you know the approximate sites dimensions in meters?
                If the search site is huge try to learn the "dervish style" whirlwind search method. It's not that easy in the beginning but if you are used to it it's fantastic and unimaginable high-speed search sessions became reality.
                This was just an additional good tip, but now I wish you good success with the buried bucket tests.
                Please keep us further informed and good luck!
                • I'm thankful geo-i for your good luck wishes and your thanks!
                  Very good luck with the accu-pack and later have really fancy
                  adventurous search-expeditions for finding the treasures!!!
                  btw. it should be possible to load the accu-pack with the
                  2 wires at 4000mA @ 14.8v - but it would take ca. 1,5h
                  to get them completly full.
                  Some Lithium-Ion accus also need a longer time for charging:
                  The original Jeohunter accu-pack needs around 6-7hours
                  with the loader I have (I guess the new one is faster).
                  You may try to load the accupack with the 2 wires at 14.8 v
                  but only with 2000mA automatically within ca. 3 hours.
                  geo-i, if your fully loaded accu-pack only lasts for 2-3 hours
                  at the Jeohunter perhaps one or two of those cells are bad.
                  Have fun my friend.
                  • Hai funfinder
                    The supplier exchane the electronic box (main Unit) he give another. it is good and ground balence very fast. Now it is Ok. i have another dought, one land 20X20 Meters on the land they laydown granite slabs full covered. granite thikness is around 6 to 10 inches. on that site jeohunter will work? signal penatrate in to the subsurface? at that condition what is approxmate depth the jeohunter will work. next the plastic drum site size is 50x35 meter. on that site they put granite slab on the drum and on the granite thye put soil. so it is also same condition. two days after i am going there.
                    • Hi
                      and thx for additonal info.
                      I cannot predict the whole situation with the granite because this depends on mineralisation level of granite compared with the soil conditions at those site.
                      The Jeohunter will penetrate the granite, this is no problem.
                      But if the granites mineralisation compensates the missing one of the barrels this could blur the contrast factor.
                      You can test the difference:
                      First bury the 10l bucket and cover it with soil only and test detection.
                      Second remove the covering material, place a granite slab over the bucket and fill the rest of the hole with usual soil.
                      If you are lucky the granite will have almost the same mineralisation level as the soil - in that case you will get 2 times the same test results.
                      If the granite has lower mineraliisation as the surrounding soil the detection would be even easier for you.
                      But if the granite compensates the ambient ground, it could make the barrels undetectable like a stealth-shield.
                      You will see this when you bury the bucket and make tests - I hope you can use the same kind of granite.
                      Of course this is the simple test, as a professional test you would have to bury everything as identical as possible like it's in real.
                      I'm glad the size of the site is only 50x35 meters. You can create 15 parts of 10x10m by markings.
                      Don't worry, you will get furthermore support if you are in need.
                      I'm confident you will find the barrels, because 100 liters of different mineralisation volume is a huge value at a depth of just 3 ft. The Jeohunter already found graves at over 6 fts. which have had a litte bit more of space.
                      It may take some patience for getting enough detection experience by tests and trials but the more experience, the better detection results you will receive.
                      • sir funfinder i just bought a Joehunter 3d my i was very glad that someone can tell me about the metal detector coz some geoengr. here says that the joehunter is an invention to scam people.. when im reading this furom i was very glad . hehehe . sir this is my problem i cant make the right depth of metal sorry for my English not really fluent in this. when i follow the video tutorial how to find the right depth im very confuse i cant really get the right cm or meter of the metal .. will i set my scan to 60x60cm or the lowest of 10x10cm or i will manually get the size of the every end of the detect metal by measuring the diameter to get the right depth?? sorry again in my english. here is the link of the video http://www.youtube.com/watch?v=F2m6M...eature=related sir can you tell me how the hell that he get that 50 x 30 cm?? did he measure it manually by using tape measure ?? im very naive in every point of the tutorial pls educate me . im a noob in hunting also ..
                        • also sir some treasure hunter in my area criticize the MD coz of the wrong spelling in the black bag maybe they give me a china made product coz of the low quality of the bag and the headset .. and wrong spelling letters outside the bag .. pls can i get the picture of your unit bag and the metal detector..
                          • Mr funfinder it is good to be here in this forum just because i purchae a jehunter 3d dual system wtiht all 3 coils , im testing my device and i think im having problems becuause of the ground banlace , i do everything as the instructions in the video to obtain the right balance and aparently the devaice gets the ground balance in a hundred percent but unfortunelly when i do the field test the device can not even detect a sold iron piece at 20 centimeters so i dont know what else to do the device only detects pieces superficially , i thank you if you could help me wiht some thanks a lot.
                            • Hi nebi,
                              I'm glad you found the right place for professional information.
                              The depth-analysis is real good (plus minus 5cm depth deviation) because of the different shapes and sizes of the objects.
                              You will need to have some experience to find the correct value:
                              Is it a short beep like when you find a coin or is it a somehow longer signal if you move over the find?
                              Most of the time you can enter 10cm x 10cm and leave it be for a quick overview scan how deep is the metal.
                              If the oscilloscope curve at the Jeohunters main screen is very low while the target gives a signal of 10x10cm it will be deep or it is a coin or something that is closer and smaller.
                              The procedure shown in the video uses the size of the metal object that is measured if you move the coils edge near the find.
                              [coil from left ->] size of find inbetween [<- coil from right]
                              (same with coil from up and coil from down)
                              It's the approximate distance when the signal between the coils edges starts you have to input.
                              After some experience you can simply use 10cm x 10cm for smaller signals and higher values only if the signal is "huge".
                              I use the depth detection very seldom because mostly I've got out the object already within the same time.
                              My bag don't has any spelling. Can you attach a picture next time?
                              As far as I know there exists no china made plagiarism of the Joehunter but a look alike clone in some arabic countries with clearly different name.
                              If you wanna be shure make a picture of your Jeohunter and your bag(s) and attach it here. Best greetings!
                              @ gart
                              This is very good you got the Jeohunter 3D with 3coils - especially for very deep treasure detection. If you are new to treasure-hunting don't worry, first you will need some experience.
                              If you have problems with the ground balance set it to value zero and set the sensitivity to 60 or 70%. Now you can bury something and test different ground balance values. After some time raise the sensitivity to 80% and next 90% and try again.
                              • Mr FUNFINDER thanks for your answer but correct me if i misunderstud your subgestions
                                1 set the ground balance at zero value no matter the percentage of the ground balance reached , go to setup before any ground balance adjust and set sensitivity in 60 or 70 .
                                2. for exanple bury something at 70 cms deep , start by setting difernet ground balance values no matter if you reach a 100 percent of the balance and check if the device detects the object then increase the sensitivity level.
                                i apologize if i did not understand well but this is it about , for me is important to achive the necesary information to make the device usefull for my propouse.
                                once again Mr FUNFINDER thanks a lot for your help
