I made Arado in 2010, it had no problems in operation.
In your photo, you used thick foil, which reduces sensitivity.
Next, you should not close the foil completely on the entire coil and it should be partially open.​
. After you build PCB , you must build a electronic-cap with range 50-300n. With this electronic-cap we can make a fine tune Rx coil.
