NARROW BAND METAL DETECTORS
I renamed these detectors SI (sine induction) detectors because there are PI (pulse induction) detectors.
When TX radiates CW - Continous Wave (more suitable term is single frequency) magnetic field, RX receives TGT signal as a narrow band in frequency spectrum. The band appears because of modulation. When search head moves, the TGT signal changes; it has a beginning, a maximum and an end as was shown before. If we stop movement, the TGT signal remains constant, ie the modulation disappears (bandwidth becomes zero) and received TGT signal has the same frequency as AIR signal . As mentioned, the bandwidth does not exceed 16Hz. So TGT signal seems on the locus in complex plane as a point despite in reality it is a very small arc or segment. If the TX circuit is competent designed, the ground can not modulate the AIR signal.
Below is illustrated AM (amplitude modulation) with carrier wave and two side bands. I think the side bands are not two for metal detectors because when AIR signal is zero, we have onlyTGT signal as a SSB (single side band),
I can make the RX of a PI machine to operte as narrow band metal detector. Then the TX (the excitating field will operate very inefficient.
