EVERYBODY KNOWS
To Qiaozhi:
1. Every competent designer knows that resistance of RX coil generates noise.
2. Every competent designer should know that R28 also generates noise.
3. Every competent designer knows how to calculate resistance of R28
in order not to significantly increase the input noise: R28 is equal or < r_coil.
4. Every competent designer knows that sensitivity of a metal detector depends on gain of preamp.
5. Every competent designer knows that the gain of this preamp circuit is R29/R28 = 100k/13k=7.7 times.
CONCLUSION: The preamp of 1220B operates, but who will say that it is competent designed.
http://www.vbox7.com/play:c0b3781c
http://www.youtube.com/watch?v=yG5e1oaen-M
To WM6: See point 4.
Originally posted by Qiaozhi
.... did I tell you i design antennas for hf radio as well ... the coil does not exist which will have lower noise input than the input terminated amplifier ... in fact the noise figure for the system will be dominated by the first amplifier noise if you can ever get your shielding good enough ( you will need triple shielded mu metal 2.5 cm thickness each shield ).
