new pulse hibrid n
  • maikl
    Senior Member Join Date: Feb 2010
    Quote: Originally Posted by WM6
    Why? Because I do not want to play in your band "Idea Robbers Brothers".
    I highly appreciate porkluvr: just as high - as I appreciate you low. Capish you frula-master?
    Ha, ha, ha it's a good WM6. It is better to say "truba"- master. And what to say to this, Mr. ..
    • And what to say to this, Mr. ..
      • From I MAIK VM6, THIS IS FOR YOU OK
        • underside of the PCB 2 star pulse 100 percent correct ,pulse is finally copied the complete star 2 and plotted all four tiles with all components .Strujasu thanks to my friend, the great help on this project.
          • anyone build this machine? Are you work?
            • that this machine works ,,,Sinko ,,,
                maikl
                OK ... this is the last comment I am going to make on this subject:
                It appears that I did not get all the abusive posts, such as the one above. This was not done intentionally. In this case, I now cannot remove the post, as it will place your recent replies (above) out of context.
                So here's the important point:
                At the top right of every post there are a set of icons. One of them is a red triangle containing an exclamation mark. If you hover the cursor over this icon, the tool tip says "Report Post". So ... if you find a post personally abusive or provocative, then click on this "Report Post" icon.
                Simples.
                • liste of components
                  Hi Orbit
                  thanks for this projetc. have you the liste of components
                  thanks you
                  pigeon
                    Hi Orbit very thanks for your great work,
                    i would like to know if you want to put here the component list?!
                    btw, your work is great.
                    all the best
                    mehdi
                    • Thanks
                      all the best
                      mehdi
                      I agree entirely, very good work and many thanks for including us in the great infos Mr Orbit.
                      I am sure that I am not alone in this matter.
                      Andy
                      • Originally posted by der_fisherman View Post
                        There are usually several reasons for using two or more PICs (processors of any type), one is that one processor simply cannot handle all the work properly, or it could be to make programming easier as you have one processor working on one job(s) and the other working the rest, or the work runs very asynchronously and a single processor simply does not have the "oomph" to jump about and do a proper job.....there could even be more reasons that I have not even mentioned......
                        Andy
                        This is completely correct, and also good example of my completely pointless and useless critical comments on this forum( i will try to avoid this in the future, keeping "low profile" and post only if i have something meaningful to say, to help someone or present some of my own projects)
                        From technical standpoint of view, C71 is now highly obsolete, it was obsolete even when that thing was built, and you can find many alternatives, ten's of times better in performance (even now and then) for almost nothing! (these things are ridiculously cheap anyway). So i'm just skeptical when solution like this appears in commercial product (OK for prototype, or project posted here, but not for full blown manufacturing). Looks like lazy and hasty job, someone didn't want to migrate from known platform or change evaluation system etc, that is why i criticize it.
                          Someone mentioned in the forums (some time ago) that the later Red Heat detectors contain 4 PICs.
                            Hi Orbit
                            You had taken more trouble for reverse engineering. I say you """Congratulation""" .
                            • bonjour j'ai besoin la liste des composons de ce détecteur
                              • Originally posted by cheurfi habib View Post
                                Please make your posts in English.
                                Compared to some of the other Treasure & Metal Detecting forums, you will find my rules to be rather simple. I pay for this web site, 100%. I do not accept advertising money from anyone, therefore I do not answer to anyone. Everyone is invited to be candid. However, Be polite. Write messages as if you are standing in
