Originally posted by moodz
I'm still trying to get my head around the basic concept so I hope you'll bear with me and my questions.
When I think of a traditional PLL (which I'm not that knowledgeable of), I expect to find a control signal that drives an error signal to zero in order to "lock" the loop. In a sense, the control signal is the output, since it is the amount of control needed to move the phase of the detector equal to the input signal in order to zero out the error signal.
So with a PLL, I feed in a signal, and my control signal is a measure of the phase of the input signal. Or something like that.
Now with a "phase amplifier", it seems the oscillator "locks onto" the input signal which can be buried in noise. Is there some signal that we can sample that is proportional to phase, like the PLL control signal, or have we really just produced an oscillator that is running at the same frequency and phase as our input signal, only now it is big and juicy and easy to sample instead of our original little noisy input?
The "phase amplifier" seems extremely fascinating, but the Synchrounous Detector still shines because A) you can make it as narrow band as you want by varying the "integration time", B) it is perfectly stable and easy to design, parts not critical, and C) it directly gives you usable output without further detection.
Well, I may have exaggerated the (C) statement a little. To truly derive phase and amplitude from the SD you need to do some arithmetic (difficult), or use some signal logic like in the TGSL. But it is still impressively simple and accurate; and what could be simpler than two switches and two capacitors?
With the "phase amplifier" idea, I still wonder about all the phase "looseness" involved with trying to synchronize oscillators, especially since we're trying to measure phase as a primary function of the MD. Maybe your sim can answer those questions if we build a little more of the MD circuitry, including the coils, into it.
The "phase amplifier" is definitely a curious circuit, especially if you read the explanations of the patent holders
!Let's keep developing it, could be basis for a new design.
-SB
