IDX-PRO+VDI
  • Koala
    Hi Kt315
    I built a DD and did not put a resistor in the TX shield. Would that cause my coil to have a lot of chatter. Coil works fine sometimes and very deep but then it will become unstable. Another coil works fine.
    Going to build another as it is also too heavy as well.
  • kt315
  • kt315
    NO REMOVE FOIL -! only isolate, take a scotch tape and make.
  • mohandes
    hi kt315
    ok (i think your means)i remove foil and nuling one of the DD coil , correct ?
  • Koala
    Originally posted by Waka View Post
    hello, I need help.
    I built two IDX and no work. PCB´s are from Silverdog. I tested the components and apparently are fine. I used the coils maxima 1500 from white's and the Spectrum XLT coil. I checked the supply voltage and correct. No sign of TX and the circuit makes sounds when my hand approached to the PCB. Both pcb have the same problem.
    Can be the problem of the pcb?
    Boards are fine built one and it works brilliant. There was a batch where one of the pads caused a short. post a high res picture of both sides of your finished boards would help. Do you have oscilloscope.
  • kt315
    Originally posted by mohandes View Post
    no guru here!!!
    ashert has wrote you -! ISOLATE ONE WINDING SHIELD FROM ANOTHER YOUR SHIELD IS SH-T.
  • Waka
    hello, I need help.
  • mohandes
    any body here use lm7808 , becuse my battery near 11.9volt and dont work the detector(in datasheet write Vi=14volt)
    correct?
  • mohandes
    no guru here!!!
  • ashefr10
    Excellent for me the shield of your 2 reels must not touch.
  • mohandes
    finish it and need to help
    hi
    i need help connection to the board.
    my shield is ok??
ID:	338043Click image for larger version
ID:	338044Click image for larger version
ID:	338045Click image for larger version
ID:	338046Click image for larger version
    the connection ok ?look the under pic ,please
  • paku
    Originally posted by eduardo1979 View Post
    Thanks eduard
  • Valters
    Hi
    I become PCB from Silverdog, realy higt quality and shipping was incredible fast.
    Now I finished my PCB, coil I make like in Silverdog`s manual for DD coils. I just wanna be sure, that I understand correct coil connection to PCB. Is this right?
    Paint ARTIST
  • mohandes
    hi
    i have some question here please answer :
    1-D3 is zener 2.7 volt or 4148???(which is better)
    2-how can i shielding them,by foil , or turn wire 0.2mm around two DD colis ??????????
    the data for my coil:
    0.7mm wire 33turn 620mkh and 1.5ohm
    0.2mm 258turn 37.5mh and 97.5 ohm
    correct?
  • eduardo1979
    Originally posted by paku View Post
    ok Thanks
    where can i get this plastic enclosures like this
    [ATTACH]26715[/ATTACH]
    Post: #195, 196
