Yor useful picture with the pot wiring has D3 one way. ->|-
Silverdogs kit pcb has D3 it the other way around. -|<-
Both of you cant be right!!
Steve
If you look carefully, you will notice that the PCB is the same as SilverDog that I published yesterday. The diodes are placed in the same direction. Look at it carefully.
The position of the D3 is correct. The original was a Zener diode and I replaced by a 1N4148 and so the poraridad Amongst the reverse. You do not worry about that. The detector is working properly. I'll post here again complete with all files updated data.
You don't be disappointed it's good detector.
You will be suprised with air test it can detect coin up to 60cm
and in ground up to 35 maby 40 with some original coil.
It's not bad at all.
Detecto
Thank You for your answer. I know how to adjust ground balance with ferrite or ground in tesoro -when I want to change GB I have to switch to All metal. Soe I see that in IDX all these procedure is in discrimination mode and not pumping ferrite just swinging, ok. I`m starting to collect all parts.
Hello, fantastic project. Just one question. How is the procedure of ground balancing on the field? I see there is no all metal/discr. switch, soe what I will have to do, pressing the pin-point and then pull up and down the coil or something else?
Regards.
Yes it's wery good detector, ground balancing is wery important for propertly working.
All you need is ferite road, so for start put your GB potentiometer in the middle position, and start swinging ferite road 10cm abowe the coil, and in the same time move your GB pot left or right, when you heard only cracking, your whites is propertly ground balanced,
and don't reject ferite road complitly you could afect sensivity on gold,
its enough to heard just cracking,
Ofcourse outdore you can fine adjust GB.
Detecto
no, I've made my own circuit board with Eduardos layout.
but it is still not finished .... must replace a few parts and even a new coil winding.
someone has written, I think it was eduardo that VR3 can be adjusted to 1kohm ..... remains on the motherboard.
Perhaps you read again by all treat. there are a lot of questions answered.
greetings marc
The circuit has been revised, and therefore agree not match pcb circuit diagram.
VR3 are used to the fine adjust angle of this delay and thereby enable a RX signal sampling at different times to the first two low pass filters of U3.
